Thread started 22 Nov 2011 (Tuesday) 08:29
lenses designed for crop cameras on 1DmkIV
Brian_R
Nov 22, 2011 08:29 |  #1
since the mkIV is kinda a crop camera although not entirely. i dont fully understand what a APS-H is versus the APS-C (which i do understand as a 7D owner and i have used FF before)
but would lenses like my sigma 30 that are designed for APS-C work on a mkiv? or would it still have some vignetting but still actually useable whereas for example EF-S just does not work on FF of course. but would a EF-S work on a 1DmkIV
im really curious as i am soon to invest in a tokina 11-16 which is meant for APS-C but in the future when money is better i am very interested in a 1DmkIV since the 1DX is way to pricey and im by no means professional.
i mainly shoot sports and the kit i would have if i added a mkIV to complement my 7D would be: 1DmkIV, 7D, tokina 11-16, sigma 30, EF 70-200 mkII
thanks. i hope this isnt too silly of a question. i tried researching the APS-H sensor but didnt find much to help me understand it :(
wimg
Nov 22, 2011 08:53 |  #2
The APS-H sensor has a crop factor of 1.3X, rather than the 1.6X of the (Canon) APS-C sensor. Third party APS-C only lenses are designed to work with 1.5X crop sensors and smaller, which essentially means that their image circle will be large enough for any APS-C sensor with a 1.5X crop or larger crop factor.
This means that these lenses won't work with APS-H sensors, they will vignette very heavily.
However, when zooming in with zoom lenses, the image circle grows much bigger. This means that these lenses designed for APS-C, will, from a certain FL onwards, no longer vignette. The same is true for the use of these lenses on FF too, BTW.
The cut-off point for the disappearance of this vignetting varies a lot with the design and FL of these lenses. With the Tokina 11-16, I think it will no longer vignette on APS-H from around 13 mm, and from about 16 mm for FF.
The Sigma 30 is a problem, because it is a prime, not a zoomlens, and will therefore vignette on APS-H full-stop. What you might find, though, is that when focusing up close, it may no longer vignette, or not as badly, because the image circle also grows bigger when focusing closer. I couldn't tell you off hand at which distance it would be vignetting free, however. Magnification wise, it probably is at around 0.25X, which likely is going to be at MFD or close to it. Its usefulness on APS-H will therefore be limited, if usable at all, and you may want to consider replacing it with a FF 28 to 35 mm lens as a result, to retain the same approximate FL on both bodies. Canon has the 28 F/1.8, 28 F/2.8, 35 F/2, 35L, you could maybe even consider the 24L or 24LII, and Sigma has a 28 F/1.8, and a 24 F/1.8 too if I am not mistaken.
Do note that 3rd party APS-C lenses, as they are designed to work with cameras with larger flange distances than Canon bodies, and because they use a standard EF-mount, will mount and work with the larger sensor Canon cameras without a problem, except for the vignetting of course.
HTH, kind regards, Wim
taltosgr
Joined Aug 2003
Nov 22, 2011 09:46 as a reply to  @ wimg's post |  #3
Since I recently acquired an 1DmkIV, I can verify that the Sigma 30/1.4 works nicely on it... but is only usable from f/1.4~f/4.0 since from then on vignetting becomes mostly visible, creating a nice black circle on the image when getting up to f/16... ;) But, no ill effects on the mirror or anything else... and of course image quality at those big apertures will continue to be excellent!
Canon EOS 1D Mark IV, 7D, 10D
Sigma 70-200 f2.8 EX OS, 30 f1.4 EX
Canon 70-200L f2.8 IS II, 24-70L f4 IS, 24-105L f4 IS, 17-55 f2.8 IS, 28-105 f3.5-4.5, 85 f1.8, 40 f2.8, 35 f2 IS
"Everyone has a photographic memory, but not everyone has film..."
Brian_R
Nov 22, 2011 10:13 |  #4
thanks guys
895 views & 0 likes for this thread, 3 members have posted to it.
1044 guests, 115 members online
