What capabilities does the nik software suite for cs5 have that the LR version doesn't, if any? If none why is it over twice the cost?
Does nik work with raw or jpg files. All the demo's I've seen have only used tiff files.
DanThoman Goldmember 2,646 posts Likes: 124 Joined Aug 2009 Location: georgia lake country More info | Nov 24, 2011 07:04 | #1 What capabilities does the nik software suite for cs5 have that the LR version doesn't, if any? If none why is it over twice the cost? Dan
cagenuts Senior Member 860 posts Likes: 1 Joined Mar 2011 Location: Johannesburg, South Africa More info | Nov 24, 2011 15:03 | #2 AFAIK, only tiff or psd. So if you're using Lightroom then once you go to Dfine or Sharpener Pro it's then in tiff so you need to do all you can in LR first then duck into the various nik products. ...Ask me anything, I'm an ultracrepidarian.
WesternGuy Senior Member 774 posts Likes: 2 Joined Jul 2006 Location: Southern Alberta, Canada More info | Nov 24, 2011 20:25 | #3 As far as I know, the Nik products work in CS5 like "layers" do - you can call up one Nik product, e.g. Viveza and it's modifications are added as a layer in CS5. You can then call up another Nik product, e.g., Color Efex Pro 4 and its effects are simply added as another layer to the image you are working on and so on. You can revert to a CS5 edit in between and it can be added as another layer to the image, so you can have multi-layered images in CS5, where some of the layers are from the actions of Nik software products and some are the result of actions or activities from within CS5. You can then save the image as a PSD and conserve all the layers. The next time you open the image, the layers are still there to be further edited, i.e., you can go back to the Viveza layer and make changes. You can, of course, save the image as a tiff or jpg, just like you can with any other image that is edited in CS5, only the layers will not be available - that is my understanding.
DanThoman THREAD STARTER Goldmember 2,646 posts Likes: 124 Joined Aug 2009 Location: georgia lake country More info | Nov 24, 2011 20:57 | #4 Thanks for the info, it's much appreciated. Dan
MusicLaw Member 124 posts Joined Nov 2011 More info | WesternGuy, Thanks for the clear and concise explanation!
krb Cream of the Crop 8,818 posts Likes: 8 Joined Jun 2008 Location: Where southern efficiency and northern charm come together More info | Nov 24, 2011 22:32 | #6 |
MusicLaw Member 124 posts Joined Nov 2011 More info | Does Photoshop Elements 10 work with layers and with these plugins? If so, are the edit session files preseved?
WesternGuy Senior Member 774 posts Likes: 2 Joined Jul 2006 Location: Southern Alberta, Canada More info | Nov 25, 2011 02:09 | #8 krb wrote in post #13447805 In addition to WG said about being able to revert changes, having the Nik filter as a layer in CS5 also means that you can use a layer mask to selectively apply the filter effects. Forgot about the layer mask aspect. Thanks for the additional info.
shazza Senior Member 486 posts Likes: 36 Joined May 2008 Location: Arizona and Florida More info | Nov 25, 2011 06:55 | #9 I first used the NIK products with just LR - advantage is, they are easy to use. Then I switched to the version that works with CS5 - and have found the ability to apply layer masks to be very useful. Sharon
MusicLaw Member 124 posts Joined Nov 2011 More info | Nov 28, 2011 14:53 | #10 MusicLaw wrote in post #13447858 Does Photoshop Elements 10 work with layers and with these plugins? If so, are the edit session files preseved? The answers are: Yes!
| Latest registered member is semonsters 926 guests, 115 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
