Help please with the above topic. I know there are endless topics on the subject but I just need a simple answer which I can't seem to find. Someone has given me a set of images to process and they are 10" x 6.662 with res 300. Ideally they should be 15 x 12 with res 300 . So here is my dilemma:
1. should I use the crop tool in photoshop and make sure resolution is set to 300
2. should I use the Image size and make sure Resample is checked and Bicubic smoother (best for enlargements) is set.
3. should I see if the client has larger images to start with (this will be the worst option as they have uploaded them via Dropbox which takes forever when there are 82 of them !)
Which method will produce the best result for printing purposes ?
