Thread started 26 Nov 2011 (Saturday) 16:26
Nik Complete setup questions
skater911
Nov 26, 2011 16:26 |  #1
So I just sprang for the upgrade to my old NIK software. I used the ps plugin prior, but since i have been mainly using lightroom I got the lightroom plugins instead. Most did not load automatically and I had to add them as an external editor. The questions I have is what settings do you use for both ps and nik (or other 3rd party editors) in the external editor.
TIFF or PSD
ProPhoto RGB
Adobe RGB
sRgb
8 or 16 bit
Resolution? defualt is 240.
For PS CS5 I have it set up as
PSD
Prophoto RGB
16 bit
300
For Nik softwear i have it the same with the exception of Tiff instead of PSD?
I am still learning when it comes to color space, bit depth and resolution so any tips or tricks are greatly appriciated.
Nikon D850 l Nikon 28 1.4E l Nikon 50 1.8 g l Nikon 24-120 F4 l Tamron 100-400 l
tonylong
...winded
Gallery: 60 photos
Nov 26, 2011 22:42 |  #2
I don't have the Nik software, so my only comment would be a concern about whether the Nik software properly handles the ProPhoto color space, PSD and 16-bit files. I'm sure someone here knows -- in the meantime, I'd imagine that the documentation for the Nik software would have some specs and recommendation...?
Tony
skater911
Nov 27, 2011 00:17 as a reply to  @ tonylong's post |  #3
Since I am still a novice when it comes to his aspect, would you recommend that I stay with 8 bit srgb?
tonylong
...winded
Gallery: 60 photos
Nov 27, 2011 00:56 |  #4
skater911 wrote in post #13456317 (external link)
Well, the best way of learning is to try!
Now, as to whether you need to be in 8 bits or 15 bits is another question. I've always used 16 bits until I have to convert to 8 bits. So you may need to do that for some plug-ins or filters. Nik may be like that.
But, you also can give thought to your workflow -- at some point 16 bits becomes pointless, and it is up to you to decide when that is the best point, rather than leaving it up to just randomly using a plug-in or filter.
Tony
MusicLaw
Joined Nov 2011
Nov 27, 2011 01:20 as a reply to  @ tonylong's post |  #5
Skater911:
As you've been using the NIK software, I just tried the Trial Vivesa 2 from LR running on a PC. Is there any way to maximize the Vivesa window to full screen? When it lauches from LR3 it is less than Maximized.
skater911
Nov 27, 2011 10:00 as a reply to  @ MusicLaw's post |  #6
I will have to check, since I use a 27 inch iMac it has always. Even large enough, when I get home I will look.
MusicLaw
Joined Nov 2011
Nov 28, 2011 14:50 as a reply to  @ skater911's post |  #7
Answered my own question here: https://photography-on-the.net …/showthread.php​?t=1119548
1,615 views & 0 likes for this thread, 3 members have posted to it.
1350 guests, 178 members online
