Thread started 26 Nov 2011 (Saturday) 16:36
Bosstrap
DarthVader
There is no such thing as Title Fairy ever
Nov 26, 2011 16:36 |  #1
Looks like a great strap to me. It's made in USA too.
http://www.bosstrap.co​m/ (external link)
Nikon/Fuji.
Gear is important but skills are very important :)
wookiee2cu
Nov 26, 2011 18:26 |  #2
Pretty much the same as a blackrapid or any other sling strap except it connects to one of the strap loops on the body instead of the tripod mount which is easy to do for the other straps. If you have a longer/heavier lens on the body I dont think I'd want to carry it connected that way though.
tomcat7886
Joined Jun 2011
Nov 26, 2011 19:56 |  #3
However, easy to stow away after taking a shot, due to single point loop.
Canon T2i | 18-55mm IS Kit | Tamron 17-50 f2.8 VC | Joby Gorillapod SLR-Zoommmmm! | Black Canon Edition Crumpler Industry Disgrace
Crumpler on Sale: BLACK https://photography-on-the.net ...ghlight=industry+di​sgrace
DarthVader
Nov 27, 2011 06:28 |  #4
It's cheaper than BR. I think it would be fine to support up to 70-200mm lens.
wookiee2cu wrote in post #13455154 (external link)
Nikon/Fuji.
DarthVader
Nov 27, 2011 06:35 |  #5
Correct, it's not a new thing, it's not his invention but improvement from WW I (per his video).
tomcat7886 wrote in post #13455512 (external link)
Nikon/Fuji.
bcd01
Nov 27, 2011 07:00 |  #6
Perhaps the competition will drive the prices down from BlackRapid!
bcd01 - devices of enjoyment list :D
wookiee2cu
Nov 27, 2011 14:25 |  #7
maverick678 wrote in post #13456908 (external link)
I'm sure it would be fine to hold that weight, what I meant was with the blackrapid connected at the camera body tripod mount and a short lens it's pretty balanced and when you have a long lens attached you connect the blackrapid to the tripod collar and it remains well balanced. With this strap connected to the camera body loop your camera is always going to be pointed at a downward angle and it you have a longer/heavier lens attached, that's a bit of stress in the lens mount.
DarthVader
Nov 27, 2011 14:41 |  #8
There will be a little stress but I doubt it will cause any harm for anything 70-200mm, 100-400mm or less. Something like 300 f/2.8 won't be suitable for this kind of strap or even BR.
wookiee2cu wrote in post #13458519 (external link)
Nikon/Fuji.
2mnycars
Nov 27, 2011 14:43 |  #9
Anyone look at the hook that connects at the base of the sling? The TriggerLock? How easy is that to open?
Dave
camera ­ dude
Nov 27, 2011 16:36 as a reply to  @ 2mnycars's post |  #10
When I miss the feel of my seat belt in the car, I'll buy one of these
7D | Canon EF-S 17-55 2.8 | Sigma EF-S 30 1.4 | Canon 85 1.8 | Canon 135 2.0 L | 430EX | TT Speed Demon | Sony RX100
djchrono
Joined Jun 2011
Nov 28, 2011 00:43 |  #11
I have one of these. I really like it. It's very compact when rolled up, easy to pop in your pocket or camera bag. The triggerlock is not easy to open accidentally, I've never had a problem with it. It's not amazingly comfortable, because there is no shoulder pad or anything, but it's much much better than the canon neck strap. If you want something simple, compact, and lets you carry your camera across your shoulder instead of around your neck, it's definitely worth checking out.
Canon 60D | Canon 24-105mm 4.0 L | Sigma 30mm 1.4 EX | Sigma 10-20mm 4-5.6 EX | Canon 580EX II
Solix
Joined Apr 2011
Nov 28, 2011 02:59 |  #12
2mnycars wrote in post #13458612 (external link)
Easy enough, but not so easy that it'll open up on you accidentally, as mentioned. I use similar trigger clasps as keyrings and clasp them onto my belt loop:
IMAGE: http://24.media.tumblr.com/tumblr_kzt98vRIOI1qaugiso1_500.jpg
Regarding the strap it seems pretty easy to make something very similar on your own. All you need is some nylon webbing, strap adjusters, trigger clasps that you can get here (external link) and a heavy duty split ring. Would probably only cost $15-20 at most including shipping too.
60D + BG-E9 | 430EXII | Sigma 30mm 1.4 | Sigma 17-50mm 2.8 OS | Sigma 70-200 HSM II | Fuji x100
POTN Feedback
Other forum/eBay feedback: 1 (external link) | 2 (external link)
DarthVader
Nov 28, 2011 04:37 |  #13
Yup I've done it with my Q and Kata neck straps. Thanks for the link!.
Solix wrote in post #13461513 (external link)
Nikon/Fuji.
calidoc
Joined Oct 2011
Nov 29, 2011 13:51 as a reply to  @ Solix's post |  #14
Regarding the strap it seems pretty easy to make something very similar on your own. All you need is some nylon webbing, strap adjusters, trigger clasps that you can get here (external link) and a heavy duty split ring. Would probably only cost $15-20 at most including shipping too.[/QUOTE]
great idea, thank you
dukessi
1 post
Joined Nov 2011
Nov 29, 2011 13:59 |  #15
WHAT A GREAT PRODUCT! While looking for a neck strap alternative for my two heavy DSLRs, I looked at many products on the market and tried out some owned by friends. Nothing even comes close to the BosStrap shoulder strap for comfort, ease of use and practicality.
The Bos Tail attachment is easily installed on the left side of the camera and then attached to the main strap by the chrome allowing the camera to hang at the perfect position to fit your hand and raise the DSLR for either horizontal or vertical shooting. And the real “biggie” as far as I am concerned is that unlike most of its competitors that attach the shoulder straps through the tripod mount on the bottom of the camera, thereby requiring its removal prior to tripod attachment, my camera with the BosStrap still attached just slides into my ballhead.
When I was shooting in Yellowstone Park this past June, I simply pulled on the strap and left it on my shoulder all day. It fits so comfortably, I would forget I was wearing it. When stopping to take shots with either my Canon 5D or Canon 7D, I just quickly snapped the strap onto the Bos Tail, got out, took my shots and then detached it when I re-entered he vehicle. I typically shoot with a wide angle mounted on the full sensor 5D and a rather heavy 100-400 zoom on the 7D for wildlife shots. Being able to switch cameras easily with the quick release buckle made using either camera a no brainer.
The BosStrap system is he best engineered, easiest to use, comfortable camera shoulder strap on the market. If you shoot more that one camera, then I suggest buying the available second Bos Tail when you order.
Duke Smith, St. Simons Island, GA
12,410 views & 0 likes for this thread, 14 members have posted to it.
Bosstrap
542 guests, 152 members online
