Thread started 28 Nov 2011 (Monday) 16:22
ISO video noise chart for 60D, T3i, T2i, and 7D
killeraxemannic
Joined Oct 2011
Nov 28, 2011 16:22 |  #1
I posted this in another thread but I saw that not everyone had seen it so I decided to give it it's own thread. This chart shows what iso settings give the lowest noise for the sensor that is in the 60D and similar cameras.
This effectively shows the isos that should be used at all times and which ones to avoid at all costs when filming!
Hope this helps!
IMAGE: http://wiegaertnerfilms.com/wp-content/uploads/2011/05/5672069943_a38b74eac8_b.jpg
Cameras: Canon EOS 60D, PowerShot Elph 330HS
Lenses: Canon EF-S 18-135mm f/3.5-5.6 IS, Canon 50mm 1.8 II, Sigma 70-300mm f/4-5.6 DG
idsurfer
Gallery: 90 photos
Nov 28, 2011 16:49 |  #2
So 1250 @ 3.2 works pretty good for indoor, overcast day, no lights on, and large bay windows (if you can imagine what that lighting might be like). Reasonably simple to manually focus on my 30 mm. THanks for the post. I was using auto ISO and getting some real bad noise at the higher ISO's.
Cory
Sony ⍺6400 | Sigma 56/1.4 | Sony/Zeiss E 24/1.8 | Sigma 16./1.4 | Zeiss Touit 12/2.8
Feedback
ChasWG
Nov 28, 2011 17:00 |  #3
Good idea posting this to it's own thread. Again, thanks!
Chas Gordon
7D Gripped/40D Gripped/10-24/EF24-70 f2.8L/EF70-200 f4L/EF50 f1.8 Mk I/EF85 f1.8
http://www.flickr.com/​photos/chaswg/ (external link)
http://vimeo.com/user9​461302/videos (external link)
killeraxemannic
Joined Oct 2011
Nov 28, 2011 22:24 |  #4
idsurfer wrote in post #13464555 (external link)
Yep I was in the same boat too when I first got my camera.
BrickR
Joined Mar 2011
Nov 28, 2011 23:54 |  #5
I've found that these sensors pretty much top out at that ISO range. My 550d is not happy at 1600 in video mode LOL
My junk
The grass isn't greener on the other side, it's green where you water it.
killeraxemannic
Joined Oct 2011
Nov 29, 2011 14:41 |  #6
BrickR wrote in post #13466567 (external link)
I don't like to go past 1250. It looks fairly ok depending on what you are recording. 640 is pretty high and looks great though! I am going to get a 2.8 lens soon so I think that will be good for low light video.
Raphael ­ V
Nov 30, 2011 11:34 |  #7
killeraxemannic wrote in post #13469706 (external link)
You can't open it up all the way to 2.8. you'll get pretty much issues with depth.
6Dx2, 80D, 450D, 24-70 f2.8LII, 70-200 f2.8LII, 17-40 f4L, EF24-105 f4L, 50 f1.8, EF-S10-22, EF-S18-135 Nano USM, EF-S18-55 IS, Sigma 24-70 f2.8, Sigma 70-300 DG 4-5.6, Vivitar f3.5 8mm Fisheye, 580 EXII, 430 EX, Nissin Pro 866II, Canon XA20, .
"Men have become the tools of their tools" - Henry David Thoreau.s.
nhttp://www.facebook.co​m …-Digitals/3460910854744​93 (external link)
V-Wiz
Joined Sep 2009
Nov 30, 2011 11:57 |  #8
Wow those are crazy. Ive shot over ISO 5,000 on my 5d II and must say im impressed.
Gripped 5D Mark II l 24-105 F/4 L l 70-200 F/4 L l Tokina 12-24 F4 l 50mm 1.8 l Sigma 600 Mirror l B+W KSM CPL l B+W 6stop ND filter l Hitech 0.6 GND l YN-468 Flash l Kenko Pro 300 1.4 TC l Induro Tripod, Vanguard 250 Ballhead.
Raphael ­ V
Nov 30, 2011 13:06 |  #9
V-Wiz wrote in post #13474359 (external link)
Well, 5d is a different beast.
killeraxemannic
Joined Oct 2011
Nov 30, 2011 14:20 |  #10
Raphael V wrote in post #13474222 (external link)
I played with it at 2.8 at the camera store in video mode. It did have a low depth of field but if you keep focus on your subject in low light video it's better than cranking up the iso and having a grainy video imho
idsurfer
Gallery: 90 photos
Nov 30, 2011 15:18 |  #11
It all depends on what you are filming. If you are filming a little kid running back and forth all around a small room, 2.8 might be a bit tricky to keep in focus d/t shallow DOF. If you are filming a couple people sitting and having a conversation (not moving a lot) you should be fine. Or how about if you are watching something on stage from a distance, 2.8 would be fine. Increase your sensor to subject distance and get greater DOF. Heck, from 20 ft away shooting with a 30 mm on an 1.6 crop camera @ 2.8 you get 16.7 ft of total DOF! You would be fine in this case.
http://www.dofmaster.c​om/dofjs.html (external link)
Cory
Feedback
ChasWG
Nov 30, 2011 15:52 |  #12
idsurfer wrote in post #13475331 (external link)
Nicely put idsurfer! And a great link.
Chas Gordon
windpig
Chopped liver
Gallery: 6 photos
Nov 30, 2011 21:41 |  #13
The results aren't surprising, they're what I've found with experimenting. It's believed that the 160, 320 and 640 are actually 200, 400 and 800 pulled 1/3 stop. The problem with using them is that you can loose some highlight detail if you push the exposure envelope. Increasing the signal to noise ratio is the ticket. 125, 250, 500 are pushed 1/3 stop from 100, 200, and 400, increasing the noise by brightening an underexposed image.
I prefer to overexpose by 1/3 stop, when I can, by using shutter speed and/or aperture.
It certainly pays off at higher ISOs.
Go ahead, spin the wheel.
Raphael ­ V
Dec 01, 2011 11:31 |  #14
Exactly. You can open it up when you want that shallow dof. But opening it up all the way just for the sake of more light may ruin some shots where depth is necessary.
idsurfer
Gallery: 90 photos
Dec 01, 2011 20:10 |  #15
windpig wrote in post #13477377 (external link)
So what ISO's would you recommend for a person that just simply wants an easy formula for the cleanest image? Sorry, I got a little lost in your post.
Cory
Feedback
10,523 views & 0 likes for this thread
Latest registered member is DaveKennard
1091 guests, 356 members online
