Thread started 28 Nov 2011 (Monday) 17:53
Some lighting setups with pictures
rgrebby
Nov 28, 2011 17:53 |  #1
Ive added some lighting diagrams to the latest post on my blog over at http://richardgrebby.t​umblr.com/ (external link)
Its pretty basic and kind rough as my original post got wiped before I managed to upload it. Im not sure how interesting it will be to people but some feedback is always welcome.
Canon 5D MKII
Canon 24-70mm f2.8L
Canon 70-200mm f2.8L IS
Canon 85mm 1.8
http://richardgrebby.c​o.uk (external link)
Mark ­ II
Nov 28, 2011 18:14 |  #2
Great shots & info. Thanks from a newbie strober.
1DX7D - 40D IR converted Sony RX100,
Canon 85 L II, EF 70-200mm f/2.8L IS II, EF 24-105L, 16-35mm f/2.8 II L, 100L & 60mm Macro , Fisheye EF 15mm f2.8, Tokina 10-17
7D_Sniper
Nov 28, 2011 20:20 |  #3
Looks good
Run it's the big bad amateur
GEAR & FEEDBACK
Help Support POTN
My Blog (external link)
http://www.hooddesigns​.com (external link)
calidoc
Joined Oct 2011
Nov 29, 2011 11:25 as a reply to  @ 7D_Sniper's post |  #4
thanks from a newbie
crazydays
Nov 29, 2011 13:20 as a reply to  @ calidoc's post |  #5
Thank you. On the bright white background are you using 2 -devoted to back and then the 2 on subject. I have a 3 light set up and have difficulty getting the total white look without editing in lightroom. Do you achieve this without editing? I too am learning. your work is beautiful!
Turning
Nov 30, 2011 10:22 as a reply to  @ crazydays's post |  #6
I found that interesting, actually, esp after couple minutes of really comparing the images and thinking about the lighting changes.
One thing that stuck me is how although I am not a big fan of blue backgrounds, I found the blue in the second background really was nicer than if it had been just a gray. The text says gray, so I don't know if it was the wb or what. But the same image with a total gray background would have been less appealling to me.
It would have been interesting to see that same shot but with grids on the front softbox as well to see the difference. I know that is not the look you were going for, just curious on how it would change the look.
I am drawn to the third shots the most though, with the high contrast. Just a personal thing.
Thanks for the time to post and explain your setup.
1,819 views & 0 likes for this thread, 6 members have posted to it.
1204 guests, 185 members online
