I mainly shoot handheld and am considering ordering the 35mm 1.4L. Coming from my 15-85mm with IS am I going to have a tough time handholding the 35mm L?
Bazinga Senior Member 362 posts Likes: 1 Joined Nov 2011 Location: Los Angeles County, California More info | Nov 29, 2011 07:48 | #1 I mainly shoot handheld and am considering ordering the 35mm 1.4L. Coming from my 15-85mm with IS am I going to have a tough time handholding the 35mm L?
smorter Goldmember 4,506 posts Likes: 19 Joined Nov 2007 Location: Melbourne, Australia More info | Nov 29, 2011 07:49 | #2 Depends on your shutter speed and your handholding ability. 1/30 or so seems ok for me on FF, but 1/50 to be safe. Wedding Photography Melbourne
Bazinga THREAD STARTER Senior Member 362 posts Likes: 1 Joined Nov 2011 Location: Los Angeles County, California More info | Nov 29, 2011 07:59 | #3 I suppose with the extra speed of the lens I'll be able to keep my shutter speed where it needs to be to handhold.
Mark_48 Goldmember 2,068 posts Joined Nov 2004 Location: Brookfield, MA More info | Have you had any problems handholding your 50mm f/1.8? Megapixels and high ISO are a digital photographers heroin. Once you have a little, you just want more and more. It doesn't stop until your bank account is run dry.
Purplecow Member 178 posts Joined Dec 2010 Location: Southern California More info | Nov 29, 2011 11:07 | #5 It is generally agreed that you don't need IS on most fast prime lenses; at least on a FF body. Many will argue that IS will add additional weight. And if you need to use faster shutter speed that you use an external flash to compensate for the low light.
smorter Goldmember 4,506 posts Likes: 19 Joined Nov 2007 Location: Melbourne, Australia More info | Nov 29, 2011 16:24 | #6 ??? Wedding Photography Melbourne
lungdoc Goldmember 2,101 posts Likes: 1 Joined May 2006 Location: St. Catharines, Ontario Canada More info | Nov 29, 2011 16:38 | #7 This is a scenario where in-body IS would be nice to have. Mark
lancebroad Senior Member 396 posts Likes: 1 Joined Jun 2009 Location: Brisbane, AU More info | Nov 29, 2011 16:45 | #8 Purplecow wrote in post #13468519 It is generally agreed that you don't need IS on most fast prime lenses; at least on a FF body. Many will argue that IS will add additional weight. And if you need to use faster shutter speed that you use an external flash to compensate for the low light. Since you're dealing with a cropped sensor, a general rule of thumb is to be able to hand hold at 1/(focal length * 1.6) to be able to not detect camera shake while hand holding. If you can hold 1/50th of second, you will be fine without IS. Why would you multiply by 1.6? APS-C cameras do not magically make the lens reach further. Its just a different crop? Canon 6D | Canon 7D | Canon 5D mkII | 14L MK II | 24-70L | 70-200 f/2.8L | 100-400L | 400L f/2.8 | Zenitor 15mm | 580EX II |
lungdoc Goldmember 2,101 posts Likes: 1 Joined May 2006 Location: St. Catharines, Ontario Canada More info | Nov 29, 2011 16:59 | #9 lancebroad wrote in post #13470337 Why would you multiply by 1.6? APS-C cameras do not magically make the lens reach further. Its just a different crop? @OP: Come on, with the ISO these days in most SLR's you shouldnt need IS on a fast prime. I can hold the 85L II at low shutter speeds. If not, ill crank it up to ISO6400. If thats a no go, I can use defused flash. Getting by without IS isn't the same as it not being useful. You do need to consider the "crop factor" in determining the limits of handholding because it is exactly the same as magnifying (or cropping if you will) a shot: movement is more visible on a poster sized print than it is on a wallet sized one. The same mm of movement is seen 1.6x larger with a crop camera with an equal lens. Mark
lancebroad Senior Member 396 posts Likes: 1 Joined Jun 2009 Location: Brisbane, AU More info | Nov 29, 2011 17:29 | #10 Its not magnified by 1.6. It doesnt get you closer. Its cropped by 1.6. Canon 6D | Canon 7D | Canon 5D mkII | 14L MK II | 24-70L | 70-200 f/2.8L | 100-400L | 400L f/2.8 | Zenitor 15mm | 580EX II |
Purplecow Member 178 posts Joined Dec 2010 Location: Southern California More info | Nov 29, 2011 17:30 | #11 smorter wrote in post #13470231 ??? You ESPECIALLY need IS on most fast primes - it's just that they don't have it. Fast primes are most often used in low light situations where IS is of benefit. Having IS on a lens like a 35L or 85L enables you to use a 4stop lower ISO. Or allows you to shoot in situations that is 1/16 as bright. Tell me that isn't needed. O And flash is never ever an ideal solution for low light. There are many situations where it is not possible, or not optimal (light quality wise) to use flash. And even when you do use flash, if you want a decently exposed photo without it looking like a cave, you will still get camera blur if your shutter is too slow
lancebroad wrote in post #13470337 Why would you multiply by 1.6? APS-C cameras do not magically make the lens reach further. Its just a different crop? @OP: Come on, with the ISO these days in most SLR's you shouldnt need IS on a fast prime. I can hold the 85L II at low shutter speeds. If not, ill crank it up to ISO6400. If thats a no go, I can use defused flash. The focal length of the lens doesn't change. However, the FOV does change for a cropped sensor body. For instance, if you have a 50mm lens on a cropped body, it frames the subject equivalent to that of an 80mm on a ff body. Therefore, instead of using 1/50 sec, you'll have to use 1/80 sec on a cropped body.
lungdoc Goldmember 2,101 posts Likes: 1 Joined May 2006 Location: St. Catharines, Ontario Canada More info | Nov 29, 2011 17:34 | #12 lancebroad wrote in post #13470489 Its not magnified by 1.6. It doesnt get you closer. Its cropped by 1.6. And a crop is a magnification, or more precisely an enlargement. You are simply wrong on this. Mark
Purplecow Member 178 posts Joined Dec 2010 Location: Southern California More info | Nov 29, 2011 17:39 | #13 lancebroad wrote in post #13470489 Its not magnified by 1.6. It doesnt get you closer. Its cropped by 1.6. The image projected onto the sensor isn't magnified.
lancebroad Senior Member 396 posts Likes: 1 Joined Jun 2009 Location: Brisbane, AU More info | Nov 29, 2011 17:40 | #14 Ugh. The image is the same as on a full frame. Its just you see less that you would on a 35mm sensor. I think you need to look into how a crop camera works. Its not bigger. Its the same, just less of it. Canon 6D | Canon 7D | Canon 5D mkII | 14L MK II | 24-70L | 70-200 f/2.8L | 100-400L | 400L f/2.8 | Zenitor 15mm | 580EX II |
Mark_48 Goldmember 2,068 posts Joined Nov 2004 Location: Brookfield, MA More info | Normal lens on a FF/35mm is about 50mm Megapixels and high ISO are a digital photographers heroin. Once you have a little, you just want more and more. It doesn't stop until your bank account is run dry.
| Latest registered member is zachary24 1443 guests, 133 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
