Before I send the camera for repair, I thought I'd check here to see if there is anything else I should try.
Problem: 7D worked fine with the USB connection and the Promote Control. Also worked with USB connection to computer. Now it will not connect to the Promote Control or the computer. (note - I was shooting with the promote control and all was fine. Unplugged it, came back 30 minutes later and kept getting the "connect to USB message.")
Tried the following:
1)Promote Control with Canon 5DMII - works fine.
2)7D USB connection to computer (several different ones) - does not show up
3)Reset all camera settings - no difference
4)Updated to Firmware 1.25 - no difference
This leads me to believe there is a problem with my USB port/connection on the camera itself. Anyone have any ideas before I ship it off? Thanks.
) - the symptoms described there are the same as mine, although the OP seemed sure that he(she) had physically damaged the USB port on the camera.
