Thread started 30 Nov 2011 (Wednesday) 14:36
7D ISSUE
Sparkz
Nov 30, 2011 14:36 |  #1
Earlier today I went out to do some shooting & the first two shots came up on my LCD completely white. No detail whatsoever. The camera wasn't aimed up at the sun or anything like that. Anyone else have this happen to them? The 3rd and all following shots were fine, but now I'm concerned about this getting worse. Any suggestions?
Mike "Sparkz"
5DMkII, 70-300 f/4-5.6L, 24-105 f/4L IS,
17-40 f/4L, 50 f/1.4, Tokina 100mm f/2.8 Macro AT-X Pro D - - - OM-D E-M1, 12-40 f/2.8 Pro, 40-150 f/4-5.6
10megapixel
"I'm a little slow"
Location: Â…Â…Surrounded by Corn and Rednecks in Indiana
Nov 30, 2011 14:45 |  #2
Could have been a lot of things. I would be suspicious of that particular memory card to start with, so try a new or different card and see if it happens again.
Gear List & Feedback
modchild
Joined Jul 2011
Nov 30, 2011 15:33 |  #3
The only time I had anything like that happen was when I had caught the dial while I was walking with it on the sling strap and it turned the exposure comp to full and ISO to max. Once I'd nearly swallowed my head with worry and changed the settings it was fine. Did you have the top dial fully locked on and everything set right.
EOS 5D MkIII, EOS 70D, EOS 650D, EOS M, Canon 24-70 f2.8L MkII, Canon 70-200 f2.8L IS MkII, Canon 100 f2.8L Macro, Canon 17-40 f4L IS, Canon 24-105 f4L IS, Canon 300 f4L IS, Canon 85 f1.8, Canon 50 f1.4, Canon 40 f2.8 STM, Canon 35 f2, Sigma 150-500 OS, Tamron 18-270 PZD, Tamron 28-300 VC, 580EX II Flash, Nissin Di866 MkII Flash, Sigma EM 140 Macro Flash and other bits.
Sparkz
Nov 30, 2011 17:47 |  #4
Thanks, I'll try a different card.
I suppose it could have been the top dial, I was so stunned by the white screen that I just turned the dial to P right away & the next shot was ok.
Thanks for the answers.
Mike "Sparkz"
booja
Nov 30, 2011 17:50 |  #5
Sparkz wrote in post #13476122 (external link)
Lol.
Probably your dial and wrong settings
Veemac
Nov 30, 2011 23:34 |  #6
You said you turned it to 'P' - what was it on before you turned it? Were you shooting in Tv or Av last time you shot? It's possible that you had one of those modes set for very low light, which would totally overexpose the image in daylight, making for a white screen like you experienced.
Mac
-Stuff I Use-
keenwerkz
Joined Apr 2011
Dec 01, 2011 00:01 |  #7
check your exif...
aps-c, a prime and a zoom...
sbattey
Joined Mar 2011
Dec 01, 2011 00:53 |  #8
You probably had it in a setting you're not usually using, and it probably had a shutter speed that was so slow that it over exposed the image.
Canon 7D | Canon 50mm f/1.4 | 430EX II
Blog (external link)
Oggy1
Dec 01, 2011 06:27 |  #9
I had a problem with my 7D where when I was out using it, the EV would gradually increase. Turned that I had not set the Lock switch for the Control Dial, and I must have been nudging it while walking around. The problem does not occur on other bodies because the Lock switch is part of the power switch.
Cheers, Oggy :)
1D MkIV, 7D (Gripped), 100-400 L IS USM, 300F4 L IS USM, 15-85 IS USM.
Oh Lord won't you buy me a 300 F2.8L
Sparkz
Dec 01, 2011 09:40 |  #10
keenwerkz wrote in post #13477900 (external link)
check your exif...
Looks like you hit it. I think somehow I managed to WAY over expose and wound up with a white out...LOL
Live & learn.
Thanks everyone.
Mike "Sparkz"
1,767 views & 0 likes for this thread, 8 members have posted to it.
7D ISSUE
1403 guests, 176 members online
