If I leave CS4 in my PC system, will installing CS5 (from the factory cd) leave a bunch of useless data on my HD and RAM use?
I could have ungraded CS4 from online, but I prefer having the cd in hand.
trailguy Senior Member More info | Dec 03, 2011 07:32 | #1 If I leave CS4 in my PC system, will installing CS5 (from the factory cd) leave a bunch of useless data on my HD and RAM use?
Merlin_AZ Senior Member 872 posts Likes: 17 Joined Mar 2010 More info | Dec 03, 2011 08:40 | #2 Install CS5. Make sure you're comfortable with it.
Arman'sPhotography Senior Member 663 posts Joined Dec 2009 Location: Milton, Ontario More info | I just upgraded from CS3 to CS5 both versions are hard copy original product from adobe purchased true amazon.ca couple years ago. I installed my cs3 back than no problem, now when i installed the cs5 upgrade edition it said my cs3 serial number was invalid?! After chatting and phone conversation with adobe they finally figured it out, and it works fine now. Be careful when buying soft copy, if your comp. crashes you could end up with nothing, god forbid you loose your receipt of purchase Toronto Wedding Photographer
| Latest registered member is Niagara Wedding Photographer 1240 guests, 148 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
