Thread started 04 Dec 2011 (Sunday) 07:14
Cactus V4s failing in the cold?
Wallpap3r
Dec 04, 2011 07:14 |  #1
Whenever I take my triggers outside when its cold (anywhere from 20-30F) my cactus triggers slowly degrade into uselessness as they get colder. At first they will be fine, then I'll have to be closer than normal, then I'll have to hold the camera way out in front of me for it to trigger at all. A few minutes after that I often can't even trigger them from inches away.
Anyone know a fix for this? Or did I just waste another $40 on weak triggers?
40D || 50 1.8 II || 18-55IS || 85 1.8 || 430EXII || YN560 x2 || Cheap umbrellas x2 || QBox 24 || Cheap macro crap
ender78
Dec 04, 2011 09:20 |  #2
This is an issue with any battery. Battery performance drops significantly even at that temperature. Have batteries in a pocket inside your jacket and switch them out. A "cold" battery will regain its performance once warm again.
D ­ Thompson
Dec 04, 2011 09:23 |  #3
I'd guess it would be the batteries.
Dennis
Canon 5D Mk III 5D 20D
I have not yet begun to procrastinate!
leeport
Dec 04, 2011 09:25 |  #4
Check out this tread.
https://photography-on-the.net …=1062291&highli​ght=cactus
There was an issue with them not working in the heat. I know yours is a cold issue, but if you go to post #19 of the mentioned thread, you might see a solution. The manufacturer had a batch that were subject and fixed the problem. Hope that helps.
rudy_216
Dec 04, 2011 15:14 |  #5
Don't assume it is the battery. Some electronic components change their value whith changes in temperture. Capacitors and inductors used in radio frequency circuits will change their value. Transistors will change the amount of gain they have.
One of the differences between better equipment and cheap crap is how well it handles conditions outside the norm. The circuit design of most of the 433MHz based radios is designed to be cheap to manufacture. (designs that use a 12 volt battery in the transmitter)
Wallpap3r
Dec 05, 2011 23:45 |  #6
leeport wrote in post #13492646 (external link)
Hmm, not sure if it would apply to the V4 models. Its definitely not the batteries, the flashes use the same batteries (eneloop) and dont have any problems
rudy_216 wrote in post #13493860 (external link)
Know any transmitters that perform well in the cold that arent as pricey as pocketwizards?
1,191 views & 0 likes for this thread, 5 members have posted to it.
1296 guests, 174 members online
