Thread started 04 Dec 2011 (Sunday) 13:03
Anyone know how to copy ONLY the jpg's and leave the RAWs behind.
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Dec 04, 2011 13:03 |  #1
On my Windows 7 machine, I have my main storage drive on the computer, and I also have a portable USB drive.
I have identical directory trees on both drives, with the tree on the USB drive consisting of empty folders with nested (empty) sub-folders.
Now, I want to copy the jpg's only from the computer to the USB drive, leaving the RAW files uncopied.
I know I can open up a couple windows to corresponding sub-folders, select the jpg's and drag. The problem there is that I have dozens of nested sub-folders (maybe even 100+), so that method would require a lot of repetitive input from me.
Does anyone know of a technique/application that can automate the process? That can copy ALL the jpg's only from one drive to another, keeping the jpg's in the correct folder/sub-folder on identical directory trees?
Rad
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
tommykjensen
Gallery: 6 photos
Joined Mar 2004
Dec 04, 2011 13:10 |  #2
Microsoft SyncToy or Microsoft Richedit both free and great. I use both.
EDITING OF MY PHOTOS IS NOT ALLOWED
Amamba
Dec 04, 2011 13:48 |  #3
Free File Sync. More configurable than SyncToy. But ST is good.
Ex-Canon shooter. Now Sony Nex.
Life Lessons: KISS. RTFM. Don't sweat the small stuff.
My Gear List (external link)
tonylong
...winded
Gallery: 60 photos
Dec 04, 2011 14:32 |  #4
So, any of those apps will automatically distinguish between jpegs and Raw files and only copy the jpegs over to the proper sub-directories? I'm askin' 'cause I don't know squat about it:)!
Tony
RodneyCyr
Gallery: 31 photos
Dec 04, 2011 14:45 |  #5
If you are familiar with a command-line interface, you could try this:
1) Press Start on the taskbar.
2) Type in CMD.EXE where it says "Search for programs..." and press Enter. This will open a window into which you may type commands.
3) Enter this command: xcopy /v/s/e/d d:\*.jpg c:\photographs
My example assumes that your USB drive is your d: drive and that you keep photographs in a folder c:\photographs. If necessary, substitute a different drive letter for d: and/or a different folder for c:\photographs.
Canon 80D, 60D, Canon 10-22EFs, 15-85EFS IS, Sigma 100-400, Sigma 135/1.8ART, Sigma 30mm f/1.4DC, Canon 60mm EFs Macro, Rokinon 8mm fisheye, 550EX flash, Olympus TG6 underwater P&S
Postprocessing: DxOLabs 5, DxO Viewpoint 3, Paint Shop Pro 2021
Speak softly and carry a big zoom.
D ­ Thompson
Dec 04, 2011 14:48 |  #6
You can set SyncToy to include or exclude any file type. It's a pretty handy little program.
Dennis
Canon 5D Mk III 5D 20D
I have not yet begun to procrastinate!
highergr0und
Joined Aug 2011
Dec 04, 2011 14:50 |  #7
It's just a basic file move using the extensions (cr2 vs jpg vs tiff or whatever)..... You could write a DOS script that would accomplish this as well.
T3i, Sigma 10-20, Sigma 30 1.4, 18-55 kit, 55-250, YN-565, a few books, some software, and a desire to get good.....
Radtech1
Joined Jun 2003
Dec 06, 2011 15:57 |  #8
RodneyCyr wrote in post #13493723 (external link)
Thanks, I will give that a try. Just so I am not completely ignorant, what do the v, s, e, and d switches do?
Rad
tonylong
...winded
Gallery: 60 photos
Dec 06, 2011 16:01 |  #9
Once you get the command window open, type "help xcopy" and it will explain the various parameters/switches you can use.
Tony
tom1s
Dec 06, 2011 16:23 as a reply to  @ tonylong's post |  #10
This is the best forum in the world. Every day I am either impressed, inspired or educated.
- I discovered I scream the same way whether I'm about to be devoured by a great white shark or if a piece of seaweed touches my foot.
cankon
Dec 06, 2011 17:03 |  #11
Easiest way is to go into the specific drive hit CRTL + F (for find) type .jpeg (if they are .jpeg) or .jpg(if they are .jpg) and hit enter. Once searching is done hit Select All or CTRL + A and copy to new destination.
Radtech1
Joined Jun 2003
Dec 06, 2011 22:40 |  #12
cankon wrote in post #13505003 (external link)
OK, that sounds even easier. Question: Intuition tells me that that will drop the copied files all into the same directory (folder). Is that true or will they (as I need) automatically populate into the corresponding nested directories and sub-directories on the destination drive?
Rad
tonylong
...winded
Gallery: 60 photos
Dec 06, 2011 22:50 |  #13
Radtech1 wrote in post #13506530 (external link)
Rad
I doubt you can do that using the basic Find and/or Search tools. I didn't really check out XCopy, did you try it?
Tony
S.Horton
Dec 06, 2011 22:55 |  #14
Ditto the xcopy command. Interesting there are still a few of us around who know how to do that.
The switches tell xcopy to walk the tree and copy all jpg files from the source to the target (d: I think it was) including all subdirectories.
Sam - TF Says Ishmael
:cool:
x_tan
Gallery: 137 photos
Dec 06, 2011 22:59 as a reply to  @ S.Horton's post |  #15
Try SyncBack Freeware, which you can select to backup some or all files / folders or drive; once or schedule:
http://download.cnet.c​om …3000-2242_4-10413802.html (external link)
Canon 5D3 + Zoom (EF 17-40L, 24-105L & 28-300L, 100-400L II) & Prime (24L II, 85L II, 100L, 135L & 200 f/2.8L II; Zeiss 1,4/35)
Sony α7r + Zeiss 1,8/55 FE
Nikon Coolpix A; Nikon F3 & F100 + Zeiss 1,4/50
Retiring  (external link)
11,699 views & 0 likes for this thread, 12 members have posted to it.
1047 guests, 105 members online
