Quick question for those of you who have shot with the 5d classic: is the AF fast enough to keep up with a toddler in lower light? Thanks!
javarob75 Member 44 posts Joined Nov 2009 More info | Dec 05, 2011 12:20 | #1 Quick question for those of you who have shot with the 5d classic: is the AF fast enough to keep up with a toddler in lower light? Thanks!
tonylong ...winded More info | Dec 05, 2011 12:22 | #2 The center AF point on the 5DC is excellent, the outer points do struggle with low light. Tony
Dec 05, 2011 13:09 | #3 tonylong wrote in post #13498365 The center AF point on the 5DC is excellent, the outer points do struggle with low light. So I've heard... But is it fast enough to keep up with a running toddler in low light?
Dec 05, 2011 13:11 | #4 fast moving in low light, not so much. .. but, if you got a prime like 50 1.4 of so crank it up to ISO1600 with low light you should be good Ben
kf095 Out buying Wheaties More info | If you keep aperture at 2.8 and wider it activates additional AF points around central AF point. They are not showing in VF. M-E and ME blog
Dec 05, 2011 13:54 | #6 thrash_273 wrote in post #13498574 fast moving in low light, not so much. .. but, if you got a prime like 50 1.4 of so crank it up to ISO1600 with low light you should be good I'll be shooting with a 28 f2.8 and a 50 f1.8...
Dec 05, 2011 13:57 | #7 you should be good Ben
GregoryF Goldmember 2,336 posts Likes: 13 Joined Jul 2010 Location: Bella Vista, AR More info | Dec 05, 2011 14:04 | #8 I think you will be fine. In a situation as this it should be as good as most consumer Canon's. 6D, 5D, 7Dii, Eos R and too many lenses, flashes and aux. gear to list!
cputeq007 Senior Member 585 posts Likes: 18 Joined Dec 2008 Location: Albuquerque, NM More info | Dec 05, 2011 15:32 | #9 Depends on your definition of "low light" and just how fast this toddler is Flickr
Dec 05, 2011 15:47 | #10 javarob75 wrote in post #13498808 I'll be shooting with a 28 f2.8 and a 50 f1.8... I'm not really sure about the 28 2.8, but I personally think that the 50 1.8 will be really bad in focusing in low light condition.
wfarrell4 Goldmember 2,551 posts Likes: 1 Joined Jun 2011 Location: NJ More info | Dec 05, 2011 16:09 | #11 Permanent banThe 50 f1.8 can't focus for its life on still subjects in the middle of the day. Will: flickr
| Latest registered member is Frankie Frankenberry 1821 guests, 148 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
