Pitter98 wrote in post #13504641
Nope, he took the picture from the same spot, adjusted down the resolution to get the items to the same size (on the computer screen), then overlaid the crop sensor (color) over the FF sensor (B&W). Just shows the max field of view that you would get from the same lens on a crop sensor versus a full frame when taken from the same position.
Thanks for this OP - I haven't seen an overlay like this done before - is definitely helpful.
kraaazymike wrote in post #13505302
I did exactly what Pitter said. Your images show that given the same pixel sized images, the crop body appears to increase the focal length. My image simply shows the change in Field of View between the two. The BW image is from the 5D2. The overlayed color image is the narrowed FOV from the XTi taken from the same location.
Ah, OK, I had to take another look at it to "get it"! I normally don't do something like that, I just post shots at my normal Web size, and they are what they are! The shots I posted clearly show the different field of view, but don't use the overlay to show the crop is really significantly smaller, hence the smaller "field of view".
team haymaker wrote in post #13505391
Tonylong, now if you made the full frame B+W and resized the cropped shot to fit into the FF shot lining up the garage you would have the same photo style as the OP.
Id like to see the garage done like this too if you have time
Heh! Well, I'll see if I want to fire up Lightroom/Photoshop for it -- 'course it should be self-evident what the result would be in fact, you could just download the two Web jegs, shrink the 30D one proportionately and convert the 5D one to B&W then overlay the 30D one, but I'll see if I can work something up and post it
