Reevo wrote in post #13508757
Hey wimg, thanks for your response. I'm definitely not an expert field, so I appreciate the constructive criticism.
I used meters instead of mm because... that's just the standard thing to do in physics a lot of the times, I guess. You're right, I could've used mm and made everyone's lives easier but.. I didn't, haha.
Bokeh is a subjective quality - you can have smooth bokeh, swirly bokeh, donut-shaped bokeh, etc, but the essential "amount" of bokeh is given by the size of the CoC. As the diameter of the CoC approaches 0, we see the image in focus.
No, bokeh is a characterisic, not a quantifiable parameter. Sharpness as in what is in DoF is - and that is what you are really calculating by calculating DoF, not bokeh.
The amount of DoF is the same thing, but I just took a different approach. Essentially the DoF calculators have a formula that calculates the diameter of the CoC as a function of distance, and finds the distance at which the CoC is the same size as a pre-determined size for each specific sensor size. That pre-determined size is the point where people would say the image is out of focus.
Actually where it is still just in fcous, based on the acuity of the human eye, at a certain print size and certain viewing distance. Slightly different approach
I don't think i'm making a mistake by converting the aperture factor to a log of sqrt(2). For instance, if the aperture factor were 1.4, then you would multiply f/2.8 to f/4. This difference is 1 stop, not 1.4 stops as it would be with your calculation.
I mentioned 1 2/3 of a stop. This is a stops factor really, so honestly, if you use the correct CoCs in the calculation, namely 0.030 mm for FF and 0.0195 mm for APS-C, you do get 1.6 stops difference. I guess I shouldn't have called it factor. It is the number of stops difference.
I checked my calculations with an DoF calculator, as you suggested. I used this one
http://www.dofmaster.com/dofjs.html
My baseline was a 7D at 50mm, d=5m, f/2.8. total DoF was 1.08m
For a 5D at 80mm, d=5m, at f/4.5 (1 1/4 stops darker) the total dof was 1.05 meters
For a 5D at 80mm, d=5m, at f/4.8 (1 1/2 stops darker) the toal dof was 1.11 meters
A tiny difference in CoC used makes a big difference in the DoF calculation. Since DofMaster doesn't give you the option to influence the CoC, I suggest you use this one, which has a few more options and allows one to fill in the exact CoC required: http://eosdoc.com/jlcalc/
I used this calculator to come up with my figures.
By default it uses a rather small CoC for FF however, so you will have to adjust that to 0.030 mm, and set CoC for APS-C to 0.0195 mm, because it uses a rounded 0.02, which also makes DoF for APS-C even bigger than it is.
Therefore, they two sensor formats achieve the same dof somewhere in between 1 1/4 stops and 1/2 stops. My hypothesis of 1 1/3 fits those requirements.
I respectfully disagree. This is what most people seem to believe, but it is not correct.
I graphed the aperture factor simply because that's how I got the answer, and I thought it would be a logical process for others too. Looking at the graph before that, it's not obvious that the factor is a constant instead of depending on the size of the CoC, so the graph makes it clear.
Please tell me what you think!\
I think that in this case, a picture is not worth a thousand words
, but maybe that is just me.
Kind regards, Wim
