Thread started 07 Dec 2011 (Wednesday) 05:07
Fine tuning lenses on a specific body
ilguercio
Joined Mar 2011
Dec 07, 2011 05:07 |  #1
About a month ago i decided it was time to get rid of some "uneveness" that i found in my Sigma 70-200 Apo EX HSM.
The trouble was i could focus to infinity at 200mm pointing the AF to a very far point in front of me but when i did that at 70mm it would just end up finding the correct focus somewhere in between 15m and infinity.
I am now going to explain how i solved the problem and then i would like to talk about your experiences.
So, as you might know there are a few metal shims inside the lens mount. Just unscrew the mount itself to reveal them. They have different thicknesses so you can finely adjust the lens to jour body.
So, after a few tweaks i ended up adding a very thin shim made from the bottom of a plastic plate (how cheap is that) . I haven't used cardboard because it was already too thick and could become thicker due to humidity. You have to be very precise when fitting the shims otherwise you could end up with a very tight mount lock because the shim is not evenly pressed inside the mount.
So i tested my lens a bit so i could understand which direction to go and now i have a perfect correspondence between the infinity mark and the actual focus.
I guess everyone should do this with his lenses as we know every camera and glass has its tolerances. The procedure is easier with a prime lens because you have just one focal lenght to adjust. With a zoom lens is like finding the "compromise" or the equilibrium point or rather the exact mounting distance at which every focal lenght focuses accordingly to the distance window.
So, has any of you did the same? Is there anybody that can tell me if this is a right procedure (it was for me) .
macroimage
Dec 29, 2011 21:32 |  #2
I'm not sure why it is important on a zoom lens for the distance scale to be accurate. Usually they are somewhat approximate. Effectively you have added a tiny extension tube so it will have a bigger effect at 70mm than at 200mm so it will make it so that you need to move the focus ring further toward infinity at the 70mm end than at 200mm so it would move the distance scale more at 70 than at 200 which would get it more "even" but then you are also giving up range beyond infinity that might be needed at temperature extremes.
What was the improvement to your pictures from making this modification?
Photo Gear
808 views & 0 likes for this thread, 2 members have posted to it.
1250 guests, 151 members online
