Thread started 08 Dec 2011 (Thursday) 07:33
creating drag and drop templates in PS....
jra
Dec 08, 2011 07:33 |  #1
I'm trying to figure out how to create drag and drop templates in PS CS4. What I want to do is create a collage template where I can easily drag photos into the collage and they will be automatically re-sized to the size I have specified on the template. So far, the closest I've come is to create a template using smart object layers and I can easily replace the photos, the only problem with this is that I must manually re-size the photos. Is there anyway to tell PS to automatically scale the photos to a certain pre-determined size? This seems like it should be pretty straight forward and easy but I can't seem to figure it out. :)
René ­ Damkot
Dec 08, 2011 08:51 |  #2
If you resize the SO in the template, that should work…
Unless I don't understand what you are asking. ;)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
D ­ Thompson
Dec 08, 2011 09:09 as a reply to  @ René Damkot's post |  #3
It should work fine as long as the new image is the same ratio as the smart object. I don't think there is a way to have it automatically adjust a 2x3 ratio image into a 4x5 ratio smart object. I don't think you'd want it to actually.
Dennis
Canon 5D Mk III 5D 20D
I have not yet begun to procrastinate!
jra
Dec 08, 2011 11:27 |  #4
René Damkot wrote in post #13513008 (external link)
D Thompson wrote in post #13513076 (external link)
I can re-size the photo as a smart object but I want it to happen automatically (aspect ratio is not an issue). For instance, if my smart object is 400x600 and I want to replace the contents with a photo that's 4000x6000 pixels, I want it to automatically be scaled to 400x600. As it stands now, when I replace the contents of my smart object, it takes on the size of the new photo instead of automatically scaling it down and I have to edit it to the proper size.
I'm attempting to create collages on a fairly large scale that contain about 10 different photos each and having to edit the size of ten photos for every single collage is a huge time waster (the photos in the collage are not all the same size so a batch processing will not work). I just want to be able to insert the photos into my template and have them automatically scaled to a pre-determined size.
sally_tomato
Dec 08, 2011 11:38 |  #5
jason, do you use lightroom? the print module in LR will do this. but it is not as flexible with respect to page layout/design as PS is. if you need more than what LR can offer, perhaps you can combine the two? the print module can output a entire page layout as a jpg, and then you can use that as a smart object/layer in your PS layout??
D ­ Thompson
Dec 08, 2011 21:53 as a reply to  @ sally_tomato's post |  #6
I think I figured out a way to do it, at least it seems to work as long as the ratio is consistent. It might be a little clunky though.
Right click on your SO and choose Edit Contents. Click OK on the window saying to save to commit.
Go to File/Place and choose the image. This should add a SO layer with the new image. Flatten. Save. It should update the original file with the newly selected image.
Hope this helps.
Dennis
René ­ Damkot
Dec 09, 2011 01:17 |  #7
jra wrote in post #13513740 (external link)
Assuming all "input" images are the same size, it should work, provided you start the smart object in the template being the size of the original image, then scaled down.
If you later drop an image 2000x3000 in the SO, you'd need to scale it up to 4000x6000 first…
jra
Dec 09, 2011 15:22 |  #8
René Damkot wrote in post #13517105 (external link)
Ok.....I figured it out :) What I was doing to scale down an image was clicking on the smart object and editing the image size to where I wanted it. Instead of doing that, I should've been using the "transform" option to make the photo my desired size. When using the "transform" option instead of an image re-size, it carries over to any image that I add.
Thanks for all of your help :)
René ­ Damkot
Dec 09, 2011 16:45 |  #9
Glad you got it done :)
4,378 views & 0 likes for this thread, 4 members have posted to it.
1314 guests, 135 members online
