Thread started 09 Dec 2011 (Friday) 07:19
Yongnuo OCF Set Up
mpix345
Dec 09, 2011 07:19 |  #1
OK, I've convinced myself that I need to try OCF for better photos of my 6 year old. (need to light her dark brown eyes better!) I have a Yongnuo YN-460, which doesn't seem to be appropriate for OCF.
Can someone recommed a decent budget option - flash and trigger - that would at least give me an idea of what is possible with OCF? I'm a bit lost trying to figure out which Yongnuo options make sense and are not overkill for what I want to do.
I'm thinking I'll get a shoot-through umbrella as well. Does that approach make sense to everyone?
Thanks!
watt100
Dec 09, 2011 07:23 |  #2
mpix345 wrote in post #13517700 (external link)
Thanks!
actually the YN460 is very appropriate for "OCF"
if you don't want to put the flash on the camera get a $25 set of wireless triggers - RF-602, RF-603, etc. works great!
mpix345
Dec 09, 2011 07:49 |  #3
watt100 wrote in post #13517713 (external link)
Awesome; thanks. I thought I read that they had to be triggered by another flash...
silent_20
Dec 09, 2011 08:09 |  #4
mpix345 wrote in post #13517779 (external link)
They can but don't have to.
60D, 430exII, 2 YN-460II, RF-602, 50mm f1.8, 55mm-250 IS and Sigma 17-50mm.
watt100
Dec 09, 2011 12:18 |  #5
yes, they have an optical trigger but for many, if not most situations it's better to use an RF wireless trigger
gonzogolf
dumb remark memorialized
Gallery: 559 photos
Dec 09, 2011 12:21 |  #6
The 460 was pretty much designed for OCF, hence the built in slave and no ETTL. If you are serious about OCF, pick up a set of wireless triggers.
BrickR
Joined Mar 2011
Dec 09, 2011 14:44 |  #7
Cheap radio triggers like Yongnuo RF602/603 or Cactus will open up a whole new world of OCF. I have 3 YN460ii's and a 560 and use the optical slave function on them all of the time. Thought I would need to purchase more triggers (only have 2) until I used the slave function. Now I want another 460ii and a 560ii but don't need more triggers.
Plus, start doubling up or tripling up your speedlights :) (double flash brackets/trishoe adapters) and let the fun begin!
My junk
The grass isn't greener on the other side, it's green where you water it.
inkista
Dec 09, 2011 16:55 as a reply to  @ BrickR's post |  #8
Yes, you're going to want radio triggers, but I'd say before spending the cash, and just to dip into OCF to see if you like it, use the YN-460's "dumb" optical slave modes, first, with your camera's pop-up flash.
If you can put the pop-up flash into Manual mode, then use S1 mode. If you can't, use S2. If you reduce the pop-up flash's output, it's unlikely to register in your final image. Start messing around with the YN-460 off-camera, and just try bouncing it. Once the limitations of the optical slave and bouncing get to you, then invest in a stand/umbrella, and triggers.
I'm a woman. I shoot with a Fuji X100T, Panasonic GX-7, Canon 5DmkII, and 50D. flickr stream (external link)
mpix345
Dec 10, 2011 07:18 |  #9
inkista wrote in post #13520274 (external link)
This seems like a great idea. But I can't get the pop up on my 60D to trigger the YN460. Switched the flash function setting to manual, and tried S1, S2 and M settings on YN460. Also tried a bunch of different camera settings to no avail.
Any ideas on settings? I would think the optical trigger is pretty straightforward?
Thanks!
dedsen
Dec 10, 2011 08:32 |  #10
If your YN460 is working the 7D flash should trigger it. If the 7D flash is in ettl you would set the 460 to S2. You cannot have the 7D flash set to master mode. There are more than 2 flashes emitted in that mode. If you set the 7d flash to manual you would set the 460 to S1. If neither of these setups work, I would say that there is a problem with your YN 460.
mpix345
Dec 11, 2011 18:31 as a reply to  @ dedsen's post |  #11
It's firing when the pop up flash fires now. Fresh batteries made the difference. Just ordered a bracket so I can attach the 460 to my tripod. I will give it a go for a bit like this and see what happens.
Thanks for the advice everyone!
devils4ever
Dec 11, 2011 19:02 |  #12
I recently bought the Cactus V5 triggers and really like them. Very reliable and cheap. Or, you can go cheaper and get a off-camera cord.
All right, then, I'll go to hell. -- Mark Twain
Canon T2i| Canon EF-S 18-55mm f/3.5-5.6 IS Zoom Lens|Canon EF-S 55-250mm f/4.0-5.6 IS II Telephoto Zoom Lens | Canon EF 100mm f/2.8 Macro USM Lens | Canon 430EX II Flash | Nissin Di466 | Slik Pro 700DX Tripod | Cactus V5 Flash Triggers
watt100
Dec 12, 2011 05:53 |  #13
mpix345 wrote in post #13528901 (external link)
you will eventually want a set of wireless triggers if you use the flash off camera a lot
inkista
Dec 12, 2011 17:23 as a reply to  @ watt100's post |  #14
ST-E2's mastering tech is old: it's basically the 550EX without the strobe. :) The LCD camera menu control of an external flash unit only came in with the 580EX II and 430EX II models.
You should, however, be able to use the buttons on the ST-E2 to command the power output level of the 565EX (in theory, at least). Remember, that the ST-E2 will not allow you to set a specific power level (e.g., 1/8, 1/2, etc.), but that you have to set groups and use groups & ratios. And you're limited to A:B groups. The C group and manual power levels were the extras the 580EX brought to the table as a master unit over the 550EX.
2,077 views & 0 likes for this thread, 8 members have posted to it.
Yongnuo OCF Set Up
1395 guests, 124 members online
