Does anyone have this turned on on their 50D ? If so to which number setting ? Any benefits / drawbacks ?
I'm thinking of getting a Noise Ninja license for PP, is that the better route to go ?
Thanks !
alexxn Senior Member 396 posts Likes: 9 Joined Nov 2011 Location: S Florida More info | Dec 12, 2011 20:30 | #1 Does anyone have this turned on on their 50D ? If so to which number setting ? Any benefits / drawbacks ? Nikon D4S, D3, Nikkor AF-S 50 f/1.4G, Nikkor AF-S 85 f/1.8G, Nikon AF-S 24-70mm f/2.8 G ED, Nikkor AF-S 70-200 f/2.8G E VR II
wfarrell4 Goldmember 2,551 posts Likes: 1 Joined Jun 2011 Location: NJ More info | Dec 12, 2011 20:34 | #2 Permanent banDo you shoot RAW? What software do you process in? Will: flickr
Dec 12, 2011 20:38 | #3 wfarrell4 wrote in post #13535410 Do you shoot RAW? What software do you process in? I shoot jpeg + RAW, use Lightroom 3 for PP. Nikon D4S, D3, Nikkor AF-S 50 f/1.4G, Nikkor AF-S 85 f/1.8G, Nikon AF-S 24-70mm f/2.8 G ED, Nikkor AF-S 70-200 f/2.8G E VR II
wfarrell4 Goldmember 2,551 posts Likes: 1 Joined Jun 2011 Location: NJ More info | Dec 12, 2011 20:40 | #4 Permanent banIf you process your RAWS, those settings will have 0 effect in LR3. They only affect the JPEG rendered screen preview and final JPEG file. Those settings are only applied to RAW files if you use DPP. Will: flickr
Dec 12, 2011 20:44 | #5 wfarrell4 wrote in post #13535452 If you process your RAWS, those settings will have 0 effect in LR3. They only affect the JPEG rendered screen preview and final JPEG file. Those settings are only applied to RAW files if you use DPP. OK, so am I better off using the built in noise reduction + DPP or Noise Ninja ? Nikon D4S, D3, Nikkor AF-S 50 f/1.4G, Nikkor AF-S 85 f/1.8G, Nikon AF-S 24-70mm f/2.8 G ED, Nikkor AF-S 70-200 f/2.8G E VR II
wfarrell4 Goldmember 2,551 posts Likes: 1 Joined Jun 2011 Location: NJ More info | Dec 12, 2011 20:51 | #6 Permanent banalexxn wrote in post #13535474 OK, so am I better off using the built in noise reduction + DPP or Noise Ninja ? Thats for you to decide. Will: flickr
Dec 13, 2011 07:20 | #7 OK thanks ! Nikon D4S, D3, Nikkor AF-S 50 f/1.4G, Nikkor AF-S 85 f/1.8G, Nikon AF-S 24-70mm f/2.8 G ED, Nikkor AF-S 70-200 f/2.8G E VR II
gjl711 Wait.. you can't unkill your own kill. 57,729 posts Likes: 4064 Joined Aug 2006 Location: Deep in the heart of Texas More info | Dec 13, 2011 07:28 | #8 If you are shooting both raw+jpeg, there is no disadvantage. The problem with any noise reduction method is that you loose data/detail. Once applied to a jpeg image, it cannot be removed. Also, in camera NR is applied over the whole picture whether it's needed or not. You have no control. As you also shoot raw, you have the data as the sensor saw it so without and NR. Not sure why, but call me JJ.
Dec 13, 2011 07:36 | #9 gjl711 wrote in post #13537228 If you are shooting both raw+jpeg, there is no disadvantage. The problem with any noise reduction method is that you loose data/detail. Once applied to a jpeg image, it cannot be removed. Also, in camera NR is applied over the whole picture whether it's needed or not. You have no control. As you also shoot raw, you have the data as the sensor saw it so without and NR. Ahh good point. I'm going to stick with PP noise reduction then. As far as Lightroom, DPP, or Noise Ninja I'll have to decide what works better for me. Nikon D4S, D3, Nikkor AF-S 50 f/1.4G, Nikkor AF-S 85 f/1.8G, Nikon AF-S 24-70mm f/2.8 G ED, Nikkor AF-S 70-200 f/2.8G E VR II
| Latest registered member is MWCarlsson 1263 guests, 173 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
