Thread started 12 Dec 2011 (Monday) 23:13
IS failure?
Simpleboy
Dec 12, 2011 23:13 |  #1
So i've had my 70-200f4 IS since the day it came out and its been perfect. However, recently about every 3rd or 4th time i use it with the IS it looks like theres a squirrel on coffee with a jackhammer deciding what the IS does. The image really shakes that much. Far more than not using the IS!
Has anyone had this problem before? Did you seek replacement or repair? If you repaired, how much did it cost?
Thanks for any help.
kawi_200
Joined Jul 2011
Dec 12, 2011 23:15 |  #2
Is it only when IS first starts up and the elements jump? Or is it a constant jackhammer the entire time?
5D4 | 8-15L | 28-135mm f/3.5-5.6 IS | 24L II | 40mm pancake | 100L IS | 70-200mm f/2.8L IS mk2 | 400mm f/4 DO IS
Simpleboy
Dec 12, 2011 23:45 |  #3
Its the whole time the IS is working. But when it happens i usually stop using IS pretty quick! If i turn the camera off and on again, it'll be fine, then a wee way down the track, it'll be jackhammering again.
kawi_200
Joined Jul 2011
Dec 13, 2011 00:38 |  #4
Definitly sounds like something with the IS went bad. I can't really help you there. Sorry it happened :(
647 views & 0 likes for this thread
IS failure?
Latest registered member is MarcusBullen
834 guests, 155 members online
