Thread started 13 Dec 2011 (Tuesday) 13:46
Brand new s95 with White dot in image
tongard
Gallery: 6 photos
Dec 13, 2011 13:46 |  #1
I just received my brand new s95 and there's a bright White dot in my low light images what should I do ? Just live with it or send it back?
Canon 6d, 7d2.
Canon 50 1.4, 28mm 2.8 is , 24-85, 24-105, 70-200 f4 is
Sigma 150-600
Jon
Joined Jun 2004
Dec 13, 2011 20:14 |  #2
Send it back - sounds like a hot pixel, and if you do much low-light work, that's a problem.
Jon
Cocker Spaniels
DoctorCanon
Joined Sep 2011
Dec 22, 2011 15:38 |  #3
I like my new electronics to be flawless. Send it back.
imjason
Joined Nov 2010
Dec 22, 2011 23:42 |  #4
depending on where you bought it, sending it back might only result in a refund and not a replacement since the s95 is being phased out. you can send it to canon. they will not fix the white dot, but instead they will map it out so you wont see it when you take a photo. if you shoot in RAW and use any of the adobe products, the stuck pixel will be cleaned out. if you plan to keep it, you can always edit your photos to remove it.
imo, if you got a good deal on the camera, i suggest keeping it since you might not receive a replacement. if replacement is possible, then try replacing. since canon doesnt really fix your camera, i suggest just removing the white dot yourself in post processing if it bothers you.
Canon gear: EOS M, Canonet QL17, SX230HS, S95, SD1200IS
Non-Canon gear: D600, D5000, D70, XG-2, U20
froughty
Joined Nov 2011
Dec 23, 2011 08:43 |  #5
fyi, I'm in the process of sending back my second s95 this month, both had spots on the LCD
2,167 views & 0 likes for this thread, 5 members have posted to it.
1426 guests, 146 members online
