Hi,
I recently purchased a Lens Doctor FD to EF converter, second hand. I've had some interesting issues, and was wondering if anyone could shed some light on this.
I tested the converter on my 7D with 2 lenses: Canon FD 50mm 1.4, and a Vivatar FD 200mm 3.5. The Vivatar looked great. No issues--exposure was correct, and the image was sharp, even wide-open at 3.5. However, the 50 1.4 had issues:
1. In both AV and M modes, the exposure was almost always too bright, by a lot, usually 2-3points off. That is, looking through the viewfinder the exposure meter, when in the middle, caused the picture taken to be too exposed. There was mention in a conversation between the Lens Doctor and the person I bought this from saying something about having to adjust exposure. But 2-3points seems very extreme.
2. The other problem is that pictures taken when opened 1.4-2.8 are VERY unsharp. Totally unsueable in any fashion. One could barely make out teeth when taken a portrait at this aperture. When at 4.0, the picture is pretty sharp. This is also the case when looking through Live View. The strange thing is, when looking through the viewfinder, the picture is very sharp. Perfect. Why the descrepancy between taken pictures and the viewfinder?
I doubt the glass in the converter is at fault since the pictures taken with the Vivatar lens are very sharp. Also I would expect if the glass is bad, that no picture would be sharp, even at smaller apertures. I am wondering if this has to do with some fancy electronics in the 7D adjusting based on lens information? The converter does have contacts to allow for focus confirmation, so maybe there is some incompatibility? I did try briefly taping up the contacts, and it seemed the problem was still the same. However, the test was brief, so not sure.
Also, from some brief googling, it appears that the Canon FD 50mm 1.4 is supposed to be pretty sharp. Not sure if it's only sharp > 4.0. But can it be ruled out that the lens is bad? Again, the picture looks perfect through the viewfinder. But for pictures taken at 1.4, it pretty much looks broken, not your typical "not so sharp cause of the large aperture" kind of look.
So, has anyone had these issues using FD -> EF converters?
If you're curious, the reason I'm going through so much trouble with this is because I asked my dad to give me his camera he used since I was a child (he doesn't use it anymore.) I can remember very well him and that camera--he took it everywhere that we went. I's very sentimental. I figured if I could take pictures through his lens, I'd remember him through the pictures. So, that's why I really want this to work.
Thanks for any help!
It's a Canon A-1 btw.)
