Thread started 15 Dec 2011 (Thursday) 19:29
580 EXII Not working on ETTL
Point-n-shoot-n
Dec 15, 2011 19:29 |  #1
Hi friends! I have a 580 EXII that severely overexposes every image shot in ETTL mode. I though for a minute that I had something set up wrong but after checking all the cfn settings everything is set to default. I have a 430 EXII that works perfectly when put on the same camera with the same settings. I figure it has to be a problem with the flash metering system. When I set it to manual and adjust the power I can get a decent exposure but not anywhere near perfect. Anybody else had this problem and if so, what was the cure?? Thanks in advance!
Canon 5D mk IV, Canon 5D mk iii, Canon 5d classic, Rebel XTI 400D 18-55 kit lens, Canon EF 85mm 1:1.8, Canon EF 17-40 F4L, Quantaray 70-300 1:4-5.6 LD, Canon 70-200 F2.8 iiL, Canon EF135 F2 L, Canon 200 F2 L, Tamron 28-75 1:2.8 , 2 alien bee 800's, 430 EXii, 580 EXii, rectangular and octo softboxes, assorted umbrellas, portable backdrops, radio triggers and still adding.............
OneJZsupra
Dec 15, 2011 20:07 |  #2
How do you have your metering system set up? It may be metering different light sources that changes what the ETTL thinks should be the correct exposure. Normally if I'm shooting people i'll do spot metering and set my shutter speed for the ambient.
Gear List | Feed Back | My Site (external link)
YN RF-603 O-ring solution
Wilt
Dec 15, 2011 20:11 |  #3
Have you checked the flash to see if FEC + is set within the flash itself?
Also, imperfect connection between the camera and flash can result in full power (overexposure of shots), even though the flash may appear to be connected properly.
110yd
Joined Jan 2005
Dec 15, 2011 20:11 |  #4
Are you using Pocket Wizards? There are quite a few posts about problems with the 580 EX II and HSS. In your gear list I noticed radio triggers. The 580 EX II does not play well with pocket wizards.
110yd
Point-n-shoot-n
Dec 15, 2011 20:50 |  #5
Thanks for the replies guys...here are the particulars as I see them. The FEC is set to 0 as are all the cfn's within the flash itself. The flash is mounted directly on the camera hot shoe. I am using spot metering with a shutter speed of 1/60. I am leaning toward an imperfect connection between the camera and flash idea as it used to just do it rarely and now it is always overexposing. I tried it on different bodies with the same results too....but like I said the 430 EXII works perfectly......always! The slider attachment lock seems to not be as tight as it once was...perhaps something has loosened up? Thanks again!
OneJZsupra
Dec 15, 2011 21:05 |  #6
Do you have triggers that support ETTL? Maybe you could try it on the trigger to see how it does?
Point-n-shoot-n
Dec 15, 2011 21:10 |  #7
I don't have any ETTL triggers Seoul...I wish I did.....I do however have an off camera cord that I may try. I didn't mention that when I say "severely overexposed" I mean almost totally white!
Point-n-shoot-n
Dec 15, 2011 21:36 |  #8
Well I tried the sync cord with a slight improvement in exposure...funny thing is my 430 EXII Didn't fare any better with the sync cord..actually did the same. I think the sync cord is the culprit here....when I attach the flash to the cord the locking mechanism gets really tight before it locks...way tighter than it does on the camera hot shoe. I think the sync cord is thicker at the attachment points and has stretched the locking cam on the flash itself making it too loose to gain a full connection..I also believe the sync cord is malfunctioning itself, hence the improper exposure with both flash units. Thanks for the quick and informative replies guys!
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Dec 15, 2011 21:39 |  #9
Point-n-shoot-n wrote in post #13552085 (external link)
That is a common behaviour when there is a problem connection. There are several known causes. You seem to have established that it is the flash unit itself which needs attention.
You may find useful information and links in my Pixel King review - see the link in my signature below.
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
OneJZsupra
Dec 15, 2011 21:45 |  #10
Hu crazy, i'll keep all of this in mind in case I run into this now lol.
Point-n-shoot-n
Dec 15, 2011 22:07 |  #11
Took off the rubber boot from the flash base as mentioned in your troubleshooting guide and got a 50% improvement...still way overexposed but can at least make out the image. I am almost certain that the connection at the hot shoe is the culprit here. Taking it to the local camera shop tomorrow to confirm, then off to canon for repairs/refitting if necessary. Thanks guys for helping me solve this problem so quickly!
StanNJ1
Gallery: 21 photos
Dec 16, 2011 07:44 |  #12
I've had similar problems with my 580 EXIIs and had to bring them into Canon for service. My units would occaisonally do a full power dump resulting in a white image and I noticed during these times that the display on the back of the flash would change from ETTL to TL. Sounds like you should just send it to Canon.
1DX, ID MKIII, 24-70 2.8L, 70-200 2.8L, 16-35 2.8L, 100 macro, 600EX-RTs, ST-E3-RT, Einsteins, Kacey Beauty Dish with a cracked grid, yada yada
www.stansphotos.com (external link)
www.Facebook.com/LikeS​tansPhotos (external link)
René ­ Damkot
Dec 16, 2011 12:24 |  #13
Point-n-shoot-n wrote in post #13552007 (external link)
Irrelevant.
What ISO, aperture and what amount of ambient? Shutterspeed is the only variable that no influence whatsoever on normal flash exposure…
If the connection is the problem, the flash is likely firing at full power all the time. That would be difficult to miss…
Check the flash foot and the seating in the shoe.
Flash foot is quite easy to DIY.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Point-n-shoot-n
Dec 16, 2011 19:18 |  #14
René Damkot wrote in post #13554802 (external link)
Irrelevant.
Wouldn't the aperture and ambient be irrelevant as well when shooting ETTL? I thought the flash would meter for the ambient as well as aperture? I checked the flash foot and can't find anything out of the ordinary with any of the contacts or their spring loadings. It appears that the foot is seating completely in the hot shoe and tightening fairly well. It used to be tighter but I believe the sync cord has stretched the cam action a bit. There is no doubt that the flash is doing a full dump all the time!
smorter
Dec 17, 2011 05:05 |  #15
Does the flash LCD say TTL instead of ETTL?
Wedding Photography Melbourneexternal link
Reviews: 85LII
2,450 views & 0 likes for this thread, 9 members have posted to it.
1099 guests, 110 members online
