Hi All,
I notice that my 5D2 may needs to take about half minute to save the RAW file with 30 seconds long exposure.
On Flickr, there were some discussion about this topic:![]()
Kinematic Digit ** says:
I can't remember for certain, but I believe Long Exposure Noise reduction actually affects RAW files. One of the two options does not and only affects JPG files. LENR uses two exposures. The extra frame is a dark frame reduction which shoots an exposure for the same length of time as the original exposure with the shutter closed, then does a comparison of the noise and removes it. It's not the same as regular noise reduction which is based on an averaging algorithm.
Just verified it from Chuck Westfall of Canon in this article:
digitaljournalist.org/issue0912/tech-tips.html
Q: The data from turning on High ISO noise reduction isn't used by third party software like Lightroom, but what about Long Exposure NR? Does the long exposure noise reduction change the actual pixel data in the RAW file or is it separate data that isn't used by Lightroom?
A: Long exposure noise reduction applies to RAW data as well as in-camera JPEGs. Adobe software such as Lightroom and ACR (Adobe Camera RAW) will "see" it because it's already in the image data before RAW conversion.
My questions are:
Can DPP, or LR3/CS5 do better job than the 5D2 in camera "pre-RAW" process?
I'm better off to turn Long Exposure noise reduction feature off or not?
Many thanks...
I shoot Raw
