Thread started 19 Dec 2011 (Monday) 11:58
Another one of those "Which Lens?" threads...
BuckyN8
Dec 19, 2011 11:58 |  #1
I am looking for a new lens to purchase and since I am spending a chunk of change, I figured I would see what suggestions everyone has specific to my case of shooting. I typically use my Canon 50mm 1.4 for EVERYTHING! I still have my 18-55mm kit lens that I bust out when needed, but I need something else. I had the 55-250mm that I recently sold because I never used it. I am going to NYC for New Years and am looking to purchase a good walk around lens for landscapes and close group shots. I love the sharpness of the 50mm and would like something that gives me the same sharpness with great depth of field. I have been looking at these lens but not sure if this is overboard
Canon 24-70
Canon 24-105
I am open to other brands that are even cheaper :) Just not sure which direction I should go. After I go on this trip, I want to use it as a lens to take family photo shoots with. I typically just shoot for family and friends as I do not market myself.
Any suggestions would be much appreciated!
Thanks!
bigcountry
Dec 19, 2011 12:01 |  #2
if you're not a pro, 24-105. if you are a pro, 24-70.
Louisville Kentucky Wedding Photographer (external link)
Travel the World and Photograph (external link)
Find me on Facebook (external link)
stockshas
Joined Apr 2011
Dec 19, 2011 12:04 |  #3
both of those lenses are not very wide on a crop (if that's what you have). if you have something like a 10-22 to complement it, either one will do. trade off between IS and the extra stop of light. last time I went to NYC, had the 50 1.8, 24-105 and 10-22 with my 7d. worked great for me.
gonzogolf
dumb remark memorialized
Gallery: 559 photos
Dec 19, 2011 12:05 |  #4
The 24-105 is lighter, has more range, and has IS. The 24-70 is heavier and has F 2.8. Both are very sharp lenses. For the amount of money you propose to spend, and considering I'm guessing you are using a crop camera. You might want to consider the 17-55 2.8 IS. A sharp lens that duplicates the function of that range when applied to a crop camera. The problem with using your suggested lenses on a crop camera is that they arent very wide on the wide end, and not that long on the long end.
BuckyN8
Dec 19, 2011 12:11 |  #5
stockshas wrote in post #13568602 (external link)
I am on a crop body. My other lens choice was a 10-22 as well, but I figured that would not be a good choice after the trip as I dont many landscape shots.
BuckyN8
Dec 19, 2011 12:24 |  #6
What are comparable off brands that are similar to the 17-55?
gonzogolf
Gallery: 559 photos
Dec 19, 2011 12:27 |  #7
BuckyN8 wrote in post #13568728 (external link)
I'm sure there are lenses in that range from most manufacturers. But that lens is very highly regarded.
Rocky ­ Rhode
Joined Apr 2011
Dec 19, 2011 12:30 as a reply to  @ gonzogolf's post |  #8
Full Frame Body -
16-35L
24-70L
Crop body -
Canon 17-55 f2.8
Sigma 17-50 f2.8
GEAR LIST Flickr (external link)
BuckyN8
Dec 19, 2011 12:31 |  #9
I was just looking at the price of it and was seeing if I could save a few bucks by buying it used. Not many people let that lens go!
Cesium
Dec 19, 2011 12:42 |  #10
bigcountry wrote in post #13568590 (external link)
And if you are a pro that's getting paid: primes.
Ok now with the joking out of the way, the 24-70 is selling at really good discounts right now. Go for it.
silent_20
Dec 19, 2011 12:43 |  #11
This is a good one. It's on sale too. http://www.bhphotovide​o.com …=endecaSearch&c​i=18587&Q= (external link)
60D, 430exII, 2 YN-460II, RF-602, 50mm f1.8, 55mm-250 IS and Sigma 17-50mm.
amfoto1
Dec 19, 2011 12:50 |  #12
BuckyN8 wrote in post #13568579 (external link)
Canon 24-70
Canon 24-105
Thanks!
First of all, since you have had a couple EF-S lenses, I'm going to assume you are using a crop sensor camera. That's fine, just has to be taken into consideration when selecting lenses.
You sound like a prime shooter who doesn't mind "zooming with your feet".
Why not look at some more primes to compliment your 50mm?
For the $1100 that the cheaper of the two L's sells for, you could get at least a couple nice primes...
EF 24/2.8 or 28/1.8 USM (I prefer the latter for it's USM, build and slightly larger aperture). One of these can serve well as a slightly wide "standard" lens on a crop camera. ($500 for the 28/1.8, by the time you add the lens hood. $400 for the 24/2.8 w/hood.)
EF 85/1.8 USM would give a more telephoto lens than what you have and is great for more candid portraits, when you have some working distance. Complements the 50mm very well. ($400, by the time you add the lens hood)
EF 100/2 USM.... is an often overlooked "sleeper" in the Canon lineup, if you need a bit more tele lens. Fast and high quality, yet quite compact. (About $500 with lens hood.)
EF 100/2.8 USM Macro (not the more expensive L)... might be a good choice if you also want a macro lens that can serve dual purpose as a moderate tele for non-macro shooting. However, it's nowhere near as compact as the 100/2 (Currently $500 plus another $35 for the hood, which is also quite large.)
There are also cheaper, but good third party macro lenses: Tamron 90/2.8, Sigma 105/2.8, Tokina 100/2.8, for example. I do not think any of these lenses will focus as quickly as the Canon USM lenses, so might be a bit less "dual purpose".
I would want to have a wider lens for use in NYC... A cheaper solution is the manual focus Bower/Rokinon 14mm f2.8... You hardly need AF on a very wide lens with so much depth of field. (Costs less than $400.)
Alternatively, you would need to go to a zoom for an ultrawide lens... there simply aren't many affordable UWA primes for crop sensor cameras. Pick from Canon 10-22; Tokina 12-24/4 or 11-16/2.8; Sigma 8-16, 10-20, or 10-20/3.5; Tamron 10-24. Prices vary from under $500 to over $700. I use and like the Tokina 12-24. It can be found used for around $400, sells new for $600.
If you still want a zoom "walk-around", don't overlook the Canon EF 28-135 IS USM. So many have been sold in kits, lightly or practically unused copies are widely available on the used market for $250, sometimes as little as $200 (check your local Craigslist). Even at it's usual new price (a little under $500 incl. hood) it's sort of a "poor man's" 24-105... has fast USM focus, IS, very good image quality... Just isn't as well built or sealed as the L-series lens. Gets a little soft at 135mm if not stopped down. I use one as a backup to my 24-70L and as a loaner if an assistant needs to borrow a lens. It's a convenient range of focal lengths, but might want to complement it with an UWA zoom for city shooting.
The EF-S 18-135 IS is a newer, crop-specific alternative... wide to moderate tele all in one lens. It doesn't have USM, but all the images I've seen done with it lead me to believe it's a pretty capable lens. It's currently on sale for $300 (normally $400)... add another $25 for a lens hood.
A lot of people really like the EF 15-85mm IS USM as a walk-around lens. It's rather pricey for a lens without particularly large aperture, but quite compact and excellent image quality. And it's a bit wider than most... nice range of focal lengths in a single lens, in fact. (About $700 currently, by the time you add the lens hood).
All the above zooms don't have particularly large apertures, but that might be fine if you want to keep your kit as small and light as possible and particularly if you have one or two fast prime lenses complementing the zooms.
If you prefer a fast f2.8 zoom as a single lens solution, it will be pricier and you end up compromising somewhere... The EF-S 17-55/2.8 IS USM is super lens, but with somewhat limited range of focal lengths. ($1100 by the time you add the hood)
An alternative that many people seem to like a lot is the Tamron 17-50/2.8 (non-VC) for about $440. The focus is a bit slower than the Canon, but it's capable of high image quality. There's no stabilization, but it's not a very essential feature on these focal lengths anyway. (There is a more expensive version with VC, but most say it's not as sharp).
There is also a Sigma 17-50/2.8 OS... I don't know much about it... It sells for a little less than $700.
Note that all the f2.8 zooms send to have a fairly limited range of focal lengths. You'd likely want to complement any of them with wider and/or longer lenses.
So, I can see several possible solutions that aren't necessarily any more expensive than what you are considering, some are actually far less expensive but would still give you more shooting options. My choice for travel with a crop sensor camera would be a reasonably compact walk-around zoom such as my 28-135 paired up with my Toki 12-24, and probably complemented with a two or three fast, but reasonably compact and unobtrusive primes, such as my 28/1.8, 50/1.4 & 85/1.8. When I am walking around with a full frame camera, I often use 24-70/2.8L complemented with 20/2.8 and 135/2.
BuckyN8
Dec 19, 2011 13:19 |  #13
All great feedback, thank you all for not bashing me for asking about "which lens is best for me", I know how that goes when you get asked the same questions over and over again. I have just been doing so much research and not been able to find a definite answer.
And as far as primes go, I do not mind "zooming with my feet", but that is the reason why I am looking for another lens that is a multipurpose. I wouldnt even mind replacing the 50mm if I find a lens that does a similar job. Remember I shoot for fun, so the small differences will not typically make a difference from a 50mm to a good walk around lens. I just love the image quality of the 50mm 1.4. I know that I will not find one lens that will give me great landscape shots while also giving me great close up candids of people. Thanks for all of the great information!
BuckyN8
Dec 19, 2011 18:22 |  #14
I do plan on going FF eventually so I am still stuck between the Sigma 17-50, Canon 17-40, and Canon 24-105. Or should I just go cheap and get the 28-135!? Decisions! Once I think I have made up my mind, I quickly change it!
kin2son
Joined May 2011
Dec 19, 2011 18:39 |  #15
I typically use my Canon 50mm 1.4 for EVERYTHING! I still have my 18-55mm kit lens that I bust out when needed, but I need something else.I love the sharpness of the 50mm and would like something that gives me the same sharpness with great depth of field.
Canon 24-70
Canon 24-105
Neither of the zoom can give you the sharpness nor shallow dof as the 50 1.4, 24-105 being worse (f1.4 vs f4 max aperture).
If you want a zoom, i'd pick 24-70 out of the 2. At least it's a f2.8 zoom.
What i'd really recommend is either tamron 17-50 non-vc or sigma 17-50 OS (both the equivalent of canon 17-55), then add another prime or two such as 85 1.8, sigma 30 etc.
5D3 Gripped / 17-40L / Σ35 / 40 Pancake / Zeiss 50 MP / Σ85 / 100L Macro / 70-200 f2.8L II IS / 430 EX II / 580 EX II / Canon 2xIII TC / Kenko Ext. Tubes
EOS M / EF-M 18-55 / EF-M 22f2 / Ricoh GR aka Ultimate street camera :p
Flickr (external link) | My Images on Getty®‎ (external link)
2,302 views & 0 likes for this thread, 10 members have posted to it.
1381 guests, 120 members online
