Thread started 19 Dec 2011 (Monday) 12:57
New IS Lens
alexxn
Joined Nov 2011
Dec 19, 2011 12:57 |  #1
So after much consideration I've come to the conclusion that I need an IS lens to do portraits, my 24-70L is lacking IS and it's showing.
The question is do I jump right in with a 70-200 f/2.8 IS, OR something else ? And if I were to get the 70-200 do I dump the 24-70 and get another wider lens to go with it ?
Decisions decisions......
Nikon D4S, D3, Nikkor AF-S 50 f/1.4G, Nikkor AF-S 85 f/1.8G, Nikon AF-S 24-70mm f/2.8 G ED, Nikkor AF-S 70-200 f/2.8G E VR II
www.alexnikolis.com (external link)
Numenorean
Dec 19, 2011 12:59 |  #2
If you need an IS lens to do portraits you probably shouldn't be doing portraits.
huntersdad
Dec 19, 2011 13:03 as a reply to  @ Numenorean's post |  #3
You might need to define portraits or describe what type you do. You shouldn't need IS to do portraits inside or out.
Facebook (external link)
http://WWW.BLENDEDLIGH​TPHOTOGRAPHY.COM (external link)
1DxIII x 2 / 24 1.4 II / Sigma 35 1.4 / 85 1.4L / 70-200L II / 300 II / AD600Pros
Rocky ­ Rhode
Joined Apr 2011
Dec 19, 2011 13:11 as a reply to  @ huntersdad's post |  #4
It does not matter what you shoot; getting the 70-200 mk II will make everything better.
GEAR LIST Flickr (external link)
mark2009
Gallery: 12 photos
Dec 19, 2011 13:15 |  #5
huntersdad wrote in post #13568968 (external link)
I would agree...if you are using a tripod you would be shutting off the (is).
What kind of portraits are you doing, and what problems, post a pic or two.
Numenorean
Dec 19, 2011 13:22 |  #6
mark2009 wrote in post #13569027 (external link)
I don't use a tripod for portraits. I found it too limiting.
alexxn
Joined Nov 2011
Dec 19, 2011 14:03 |  #7
OK maybe I need to clarify....because of the outdoor settings I am shooting in (uneven terrain, the beach, sometimes in tough positions, etc) a tripod isn't doable at all. Regardless my hands are not the steadiest for some reason so it's compromising my sharpness which I am blaming on movement.
Perhaps I am not 100% correct with this and maybe a faster shutter speed would correct this. I assumed lenses have image stabilization for a reason but I could be wrong here :cool:
kory
Joined Oct 2011
Dec 19, 2011 14:10 as a reply to  @ alexxn's post |  #8
You really should use a monopod if a tripod is not an option. Notice all of the NFL guys still use monopods even with monster lenses with IS (granted part of that might be due to weight but it still helps). You just miss too many shots shooting freehand even if you have fast aperature. Also primes are almost always sharper than zooms. Having said that the 70-200 is the best lens canon makes you should go for it.
amfoto1
Dec 19, 2011 14:32 |  #9
Some people have conditions that cause hand tremors and such, so I try not to assume anything, even though personally I have no trouble handholding my own 24-70 without IS.
I'd suggest 24-105 IS, 28-135 IS... they offer pretty close to the same image quality (it would be hard to tell apart 11x14 prints from each), even if they lack the f2.8 aperture of your 24-70.
If you still need f2.8, you might look at third party lenses... Sigma has some fast ones with OS, their version of stabilization which is pretty comparable to Canon's IS. There are also some VC Tamrons and VR Tokinas, but I really don't know very much about them.
I'm afraid a 70-200 will simply be too long for a lot of portrait work on a crop camera.
Prime lenses really don't help, though they might have larger aperture that allows a slightly higher shutter speed.... Canon 50/1.4, 85/1.8 are very good portrait lenses. 100/2 is another possibility, though starting to get a little long on crop cameras for some portraits. There is also the Tamron SP 60/2.0 macro/portrait. But, there's no IS on any of these.
Shorter lenses that might work include the EF-S 17-55/2.8 IS. The EF-S 15-85mm IS actually has a wider range of focal length than your 24-70, but is f3.5-5.6.
Yes, a tripod would be ideal... a monopod is a possible alternative. And, without knowing your level of experience, simple practice and working on hand holding techniques can make for a lot of improvement.
DreDaze
Gallery: 49 photos
Dec 19, 2011 16:57 |  #10
if you're taking pictures of things that move you'd want a shutter speed that wouldn't be affected by IS anyways on a 24-70mm...
Andre or Dre
gear list
Instagram (external link)
huntersdad
Dec 19, 2011 21:29 as a reply to  @ DreDaze's post |  #11
Alex, Post a couple pics that think have compromised sharpness, so we can see the settings. If you're doing lanscape or macro stuff handheld, I can kind see the needing the IS thing handheld. For portrait work though, I can't see it being a benefit outside unless you are shooting in extreme shade.
Shooting at 70mm on a crop, your SS should be around 1/125 to prevent shake from showing. I'm assuming a crop because it only gets shorter from there.
So give us some examples.
thestone11
Joined May 2011
Dec 19, 2011 22:13 |  #12
post some samples along with their metadata....that way we can give some comments. I do portraits with my 24-70 all the time and it is an amazing lens. I don't think the lack of IS has limited me at all.
Canon 5D MK II | Fuji X100 | Canon T2i | Canon 100mm macro f/2.8 | Canon 135L f/2 | Canon 50mm f/1.2 L | 17-40mm f/4 L | 24-70mm f/2.8 L | 70-200mm f/4 L IS USM |Canon 430EX II Flash X2 | Pocketwizard TT5 & TT1
OneJZsupra
Dec 19, 2011 23:16 |  #13
I love my 24-70..... Are you taking these at midnight or something? I imagine with the correct lighting gear you'd be fine in any situation for portraits.
Gear List | Feed Back | My Site (external link)
YN RF-603 O-ring solution
Relaxtech
Joined Dec 2011
Dec 20, 2011 03:04 |  #14
alexxn wrote in post #13568935 (external link)
Why do you need IS for portraits? Aparture good enouhgt for portraits so that shutter speed coming to quick not need IS in this case. 70-200f/2.8IS is best lens using in the critical light condition. If your budget are good the 70-200f/2.8IS is the best choice for portraits.
40D, 7D; 17-40f4L; 85f1.8; 70-200f4L
iLvision
Joined Oct 2011
Dec 20, 2011 03:13 |  #15
You need to know how tk use the lens. I think people misuse their lenses sometimes. I almost never have a problem with my 24-70, having non-blurry shots that is. However, I did have a problem with the original 70-200L I had. So I upgraded to a 70-200L IS II and it is a "WOW" lens!!
Use the right teqnique using your 24-70 and get a 70-200L IS II, that's all I can tell you. Believe me or not, I had KEEPER shots at 200mm at 1/20 of a second from the 70-200L IS II. You need steady hands to pull something like this. Some people need 1/30 or higher even with IS.
Ilya | Gear | flickr (external link) D800| 14-300mm f/1.4GL ED VR III USWM
2,505 views & 0 likes for this thread, 19 members have posted to it.
New IS Lens
1265 guests, 172 members online
