Thread started 20 Dec 2011 (Tuesday) 04:14
Strange Issue with YN-467
abjam77
Dec 20, 2011 04:14 |  #1
My YN-467 is acting very strangely. When the flash head is tilted at 75 degrees and 60 degrees, the flash will not fire at all, but in any other position it fires every time. I've tried recharging the batteries, changing modes, and turning it off and on - nothing seems to work. I'm just pressing the pilot button, not even trying to trigger the flash with something else. It seems like there must be something physically wrong with the connection at 60 and 75 degrees, but that seems strange because it works perfectly at 90 and 45 degrees. Has anyone else had a similar problem? Or any ideas for a solution?
Portfolio (external link) : Blog (external link)
Canon 5D | Tamon 17-35 | Tamron 28-75 2.8 | Tamron 70-300 VC | Canon 50mm 1.8 | Canon 85mm 1.8 | Canon 430EXII
Lisa
"At least once a day"
Dec 20, 2011 13:06 |  #2
Sounds like its defective, I have the yn-467 on my 60D and it doesn't do it. It is a cheap flash, sometimes they do have problems.
Gear (full list)
Canon 6D & 60D
Photobucket (external link)
abjam77
Dec 20, 2011 14:02 |  #3
What's weird is that it wasn't like this when it arrived, it only just started to develop the issue.
alex.hondsmerk
Joined Nov 2011
Dec 20, 2011 17:28 |  #4
Like you said, it sounds like the contacts have physically broken or worn away. Mine doesn't do it.
Time to treat yourself to a new speedlight maybe?
Gripped 50D, 24-105 f/4 L, 70-200 f/4 L, EF-S 17-85, 50 f/1.8 II "L" (external link), Tamron 60 f/2 Macro, Samyang 8mm fisheye, 430EX
abjam77
Dec 21, 2011 01:23 |  #5
Nothing like an excuse to upgrade to the YN-565 :P I think i'm going to just use it in the positions that work for the time being. I can live without 60 and 75 degrees...
1,122 views & 0 likes for this thread
Latest registered member is raytracer
955 guests, 324 members online
