Hello, First off let me say that I'm totally new to Canon products as I've recently been selling off my Olympus DSLR gear ( still have a couple of great lenses if anyone's interested). I'm trying to decide between the 7D or 60D. I plan on using it primarily for wildlife and BIF use. I plan on buying the 400L 5.6 lens at the same time as well.
I have a list of questions that I'll put here seperatly. I know the 7D may have some focusing issues as some have reported but I'm not ruling it out because of that.
Does the 60D have any issues that I need to be concerned about, any known flaws etc.?
Does the dual Digic 4 processors in the 7D make a big difference vs. a sgl. one in the 60D?
Is the FPS difference a big deal? I'm new to taking BIF photos so not sure how critical it would be.
I believe the 60D does not have the AF microadjust. Is this a must have feature?
Do both models have an equal AI servo mode as far as tracking BIF is concerned?
Will the 1.4 extender work equally well on both cameras using the same lens, like the 400 5.6?
I have only shot JPEG up to this point but might try RAW also. Is one model better suited for JPEG for any reason?
Is the type of memory card a concern, SD vs CF? Does one type generally have better image quality if I use high grade cards?
Is the 19pt. AF of the 7D that much of an advantage over the 9pt of the 60D?
Video is not a concern for me at all.
Is the 7D the only one that has the spot focus feature?
I assume the slightly larger LCD on the 7D is not a big deal or is it?
I have no problem spending the extra money on the 7D if it is justified and an advantage for the type of photographs I plan on taking as mentioned above.
If the 60D will suit my needs just fine in you peoples opinion, that's fine and then I can put the extra money towards my hope of buying a used 500 F4 lens in the future.
Are there any other sites that have a history of giving good reviews of cameras? I'm only familiar with DPreview.
I appreciate all your opinions, pro or con as this forum seems to be THE place as far as Canon knowledge is concerned.
I would describe my DSLR knowledge as definitely above a point and shoot level but still a ton to learn on the DSLR front and I'm not afraid to experiment to see what works best for me as I know there is no such thing as a perfect camera that works for everyone.
Thank you very much.
Bob
:p
