Thread started 23 Dec 2011 (Friday) 08:08
Canon 50D acting up in the cold
KROHN27
Dec 23, 2011 08:08 |  #1
So i've been shooting in about 15 degree weather, and within 10-15 minutes of being outside, my battery grip starts becoming non-responsive. Half pressing the shutter won't start focusing, and then I will full press and it will skip focusing all together and just shoot. Then sometimes it will focus with the grip, and then a full press won't activate the shutter at all. The grip is canon brand, and I've been using the 70-200 2.8 IS. Does anyone have any ideas, or ideas/suggestions?
5D MKII | 5D MKIII | 40mm | 50L | 70-200 2.8L IS | 24-105L | 580EX II
John ­ from ­ PA
Joined May 2003
Dec 23, 2011 08:37 |  #2
As a starter, be absolutely certain the batteries are in good shape!
Ramon-uk
Gallery: 61 photos
Dec 23, 2011 08:47 |  #3
Could be just a poor connection between the grip and the camera.
Try the camera without the grip for a while and see if the problem crops up again.
If it doesn't then clean the contacts on the grip before refitting it.
2mnycars
Dec 23, 2011 08:50 |  #4
Ramon-uk wrote in post #13589581 (external link)
bw!
Thanks! Others may have better tools. I would first wipe the contacts with a microfiber cloth. Then if I needed to be more aggressive, I would use a pencil eraser for a little more aggessive cleaning.
My grip on my d80 would loosen up with time. First time--couldn't take an exposure. So--Every time I took the camera out, I would tighten the connector to make sure I could take an exposure.
Dave
Kiwikat
Dec 23, 2011 08:51 as a reply to  @ Ramon-uk's post |  #5
This has happened to me before. I had to re-tighten the battery grip. The temperature changes and going in and out of my bag loosened it up. Not sure if you're having the same issue though...
"Would you really want to be the Canon rep responsible for dealing with POTN?" -FlyingPhotog
Nikon D500
KROHN27
Dec 23, 2011 08:59 |  #6
Thanks for all the advice, I'm betting it's something to do with the contacts. Unfortunately I'm out of town and I don't have the battery door for using just the body without the grip. When I was shooting, and my grip wasn't working, I had no issues with the body itself acting funky (which is a relief). At what temperature does it become damaging to body? I know it's not nearly cold enough here, but just curious if anyone knows.
rick_reno
Dec 23, 2011 09:04 |  #7
Cold shrinks stuff, and since on the camera various pieces are made from different materials it shrinks differently (amount and rate of shrinkage). Clean things up and tighten and try it again.
Hermeto
Dec 23, 2011 09:12 |  #8
rick_reno wrote in post #13589635 (external link)
So, it is the shrinkage after all! :D
http://www.youtube.com …nKLhi83J8&featu​re=related (external link)
rusty.jg
Dec 23, 2011 09:22 |  #9
KROHN27 wrote in post #13589617 (external link)
You probably already know this but just in case someone else doesn't - I *think* there is a slot for the battery door on the grip itself so you can store the battery door on the grip while using it (but I'm not 100% sure).
There definitely is on the 5D2 grip and I suppose there roughly the same size.....
to be OR NOT to be = 1 (which is "to be" so that one's cleared up at last ;-)a)
www.VividCornwall.co.u​k (external link) (external link)
Sony Nex-5n (x2) / Metabones EF-NEX Smart Adapter / Canon 10-22mm / Canon 100mm Macro / Sigma 18-50mm
1,789 views & 0 likes for this thread, 8 members have posted to it.
856 guests, 174 members online
