Thread started 27 Dec 2011 (Tuesday) 09:38
Normal for 5DII? A few items...
MNUplander
Gallery: 10 photos
Dec 27, 2011 09:38 |  #1
Hi everyone -
I just got a new 5DII last week and noticed some strange things happening that I wanted to know if they were normal or not. I was hoping some of you could tell me if I should be sending it in or not.
-When connected to my 430EX II, it would seemingly randomly fire a high-speed synch flash burst for about a second. This occured twice in 4 days of family shooting. [LIKELY HIT DOF PREVIEW BUTTON W/ FLASH ATTACHED]]
-Image playback button seems un-responsive for a short time (5-10 seconds?) after taking an image. This occurs more frequently but not all the time. [BAD CF CARD MAYBE]
-I took a couple short videos and upon trying to locate them in playback, it said "image not available" in the spot where the video should be. Images were fine. Then, it displayed a message about a problem with my CF card (dont recall exactly what it said - maybe error "02"?). I turned the camera off then on and it seemed resolved. This happened once. [BAD CF CARD MAYBE]
-Is the metering different from the 5D? The 5DII seems to under-expose by about 1 1/3 stops compared to my 5D but this could just be a learning thing for me. It actually seems to match the look in the room a bit better, but there are definitely more under-exposed areas than the metering in my 5D would have chosen (aperture priority). [LIKELY USER ERROR]
-How much should I be able to push my shadows in post at say 3200-6400 ISO? It seems like if I touch them at all I get weird red noise in my shadows, sometimes its slightly noticeable even without touching the shadows. This could also be my in-experience using high ISO coming from the 5D that I never used above ISO 800. [NORMAL]
Thanks so much!
Lake Superior and North Shore Landscape Photography (external link)
Buy & Sell Feedback
R6, EF16-35 f4 IS, EF 50 1.2, EF 100 2.8 IS Macro, 150-600C
Higgs ­ Boson
Dec 27, 2011 09:59 |  #2
- possibly half pressing the shutter button sometimes and it is metering?
- CF card new or old?
- CF card seems to have issues
- could be using a different metering mode, read up on exposing to the right
- expose to the right to avoid shadow banding
A9 | 25 | 55 | 85 | 90 | 135
MNUplander
Gallery: 10 photos
Dec 27, 2011 10:04 |  #3
Higgs Boson wrote in post #13604642 (external link)
Same metering modes used...and I did mitigate using ETTR, but a guy gets concerned when he spends 2k on a camera and metering doesnt seem quite right. I was more just curious.
Its a new CF card that seemed to work fine in my old original 5D. Maybe re-format using the 5DII?
Thanks for your input.
Buy & Sell Feedback
TheBigDog
Gallery: 34 photos
Dec 27, 2011 10:05 |  #4
Are you sure #1 isn't from hitting the flash exposure lock button? I found it a lot easier to hit it on my 5dmk2 than my 7d. I don't think I hit it once on the 7d since the button is more recessed, but I'm always hitting it on the 5dmk2. But it causes the flash to rapidly fire for about a second.
Christian
http://www.cegphotogra​phy.com/ (external link)
Member, Full Disc Aviation (external link)
Flickr (external link) * Facebook (external link)
Instagram (external link)Aviation Instagram (external link)
MNUplander
Gallery: 10 photos
Dec 27, 2011 10:10 |  #5
TheBigDog wrote in post #13604668 (external link)
Its possible - Ill handle it at home to see if my finger finds that button more easily than I thought...good idea.
Buy & Sell Feedback
Mr. ­ Blue
Dec 27, 2011 10:11 |  #6
- You are probably hitting the Depth-of-field preview button. I have done this on many occasions. With your flash on, it will serve as a 'modeling light' and fire at high power for about a second. See the link for where the button is located. ( right near the base of the lens...very easy to push by accident. I do it all the time still. :lol: )
http://dcuser.net …-5d-mark-ii-diagram-1.png (external link)
- Maybe your buffer is full during this time?
- I noticed the same thing when I first switched to my 5D MKII from a T2i. Personally, I just think that the LCD isn't as bright as my old camera. Once I looked at the images in Lightroom, they appeared to be correctly exposed.
- At those ISO speeds, I wouldn't expect to be able to push them too much without hitting them hard with NR.
Gear
flickr (external link) | 500px (external link)
TheWitnessStudios.com (external link)
musashi
Location: Winchester, CA / San Diego, CA / North Hollywood, CA
Dec 27, 2011 10:13 |  #7
Maybe your hitting your dof button close to the lens release button. I think when you have a flash it activates your modeling lamp.
-Image playback image button seems un-responsive for a short time (5-10 seconds?) after taking an image. This occurs more frequently but not all the time.
I dont know, but mine shows the pics ad soon as i pushed the playback button. I usually half-press the shutter before pressing playback.
Dont know again. Maybe your memory card is going bad? Also make sure that you format in-camera before using specially if your cards are being used on different bodies.
“You can easily judge the character of a man by how he treats those who can do nothing for him.”
--==Gear List & Feedback==--
Echo63
Dec 27, 2011 10:22 as a reply to  @ TheBigDog's post |  #8
The only one I can answer is #1
You have hit the Depth of field preview button.
I think it's a bit further down from the lens release button.
(on the 1d it's the plastic bar sticking out near your little finger)
Hitting it with a flash on will cause a second of strobing to act as a "modeling light"
I actually wish I could AF as it was doing it, would make working in the dark easier
My Best Imageswww.echo63.deviantart.​com (external link)
Gear listhttps://photography-on-the.net …p?p=2463426&pos​tcount=385
amfoto1
Dec 27, 2011 11:16 |  #9
MNUplander wrote in post #13604534 (external link)
Hi everyone -
Yes, I suspect it's what a couple others have suggested... you are accidentally pressiing the DOF button on the front of the camera... When a flash is mounted and powered up, that button gives you a flash preview/modelling lamp effect instead of DOF preview. It's really easy to press the button with your left hand, when "cradling" the camera and lens.
Could be several things... but basically it takes a little while for the image to be stored on the memory card. Exactly how long varies depending upon some of the camera's settings and the speed of the memory card. 5DII can use faster UDMA memory and take advantage of 300X or 45MB/sec memory. Faster than that, it really doesn't use... limited by the camera's write speed abilities.
Settings that can effect the time it takes to file an image include noise reduction (definitely Long Exposure, which takes a second "blank" shot to compare noise and deduct it... the second shot takes as long as the first one, whatever that happens to be)... also possibly Peripheral Illumination Correction, Highlight Tone Priority and Auto Lighting Optimizer... if you have any of those enabled.
RAW images are large and will fill the buffer and slow down the camera more quickly. RAW + JPEG, even larger and slower to process. JPEG, expecially the smaller ones, are the fastest, but the camera is throwing away a lot of unrecoverable data in the conversion process (all images start out as RAW files, if you set the camera to "shoot JPEG", it's just converting the image in-camera).
I don't shoot video, so am not sure about this. Do you regularly format your memory card in the camera before using it? (I'm in the habit of formating in-camera every time I put a fresh mem card in... This erases any images remaining on the card, so be sure to remove or copy any you want to keep.)
Another possibility is the memory card isn't fast enough. However, video isn't really all that demanding. I think Canon has info on minimum card speed (which is surprisingly low, if I recall correctly) in the instruction manual.
AKAIK, the metering system is the same as in the 5D. If you are judging by the image review on the LCD... well, don't do that. The LCD isn't calibrated, is highly subject to ambient light variances, is governed by whatever Picture Style you happen to have set, and the brightness of the LCD has sort of a crude auto brightness adjustment (unless you disable it).
Learn to use the histogram instead. It's much more accurate info about exposure accuracy (but be aware that it is also effected by the Picture Style that's set, even if shooting RAW, since the histogram is always based upon the preview JPEG embedded in the RAW file)
The best way to evaluate images is with a print done on smooth, matte paper. The second best way is on your computer... And it's best if it's a desktop computer always being used in consistent viewing conditions and if its monitor is properly calibrated. Laptops are a lot harder to calibrate well, since they are used under a wide variety of viewing conditions and different light sources, plus the viewing angle of the screen is hard to keep consistent.
We all have different expectations when it comes to noise... what we each consider "acceptible". So this a tough question to answer. I will use my 5DII up to 6400 without much concern... But if the image is of a subject or scene with a lot of dark areas or shadows, more noise will be present. I'll use the higher ISOs more rarely, but I always expect to do a lot more post processing, or possibly have to convert the image to black & white. I shoot RAW and don't use in-camera noise reduction.
The key thing is to avoid underexposure. It also makes a big difference what software you use for RAW conversions (assuming you are shooting RAW). Canon DPP is pretty darned good handling noise. Lightroom 3 is much better than Lightroom 2, and Photoshop CS5 has far better noise reduction than previous versions.
There are also tricks you can do, depending upon what software you use... Such as selective noise reduction just in the shadows or dark areas of an image, if NR isn't needed in the brighter areas (I'd use Photoshop and layers to do that.)
But it's still best to avoid underexposure as much as possible. If you have to dial up the exposure in post, that amplifies noise a lot. A lot of people shooting with Canon in any of the auto exposure modes (Tv, Av, P) will set a slight bias with Exposure Compensation... +1/3 or +2/3 stop. This is just a blanket precaution to try to avoid underexposure (but you still need to know how to read a scene and dial in any other necessary compensation, to correct for the inherent errors in any reflective metering system... see Bryan Peterson's "Understanding Exposure" for more info about this). This is called ETTR or "Expose-To-The-Right", since you are dialing Exposure Compensation 1/3 or 1/2 or 2/3 stop to the right of center (the + side) as a starting point. There's a lot of discussion of this on www.luminous-landscape.com (external link), too.
The general idea is that it's better to slightly overexpose than to underexpose.... pulling back or dialing down exposure is much safer than pushing it or dialing it up... Gives a much cleaner image. Part of the reason for this is that there's more "headroom" to protect highlights than we realize. You likely won't see it on your computer monitor... will only see how much highlight and shadow detail there really is if you make a print from the image on smooth, matte paper. That's the best way to fully evaluate an image.
5DII handles a higher dynamic range than most DSLRs. But at some point it's limited and you might want to read up on High Dynamic Range or HDR techniques, too.
MNUplander
Gallery: 10 photos
Dec 27, 2011 12:46 |  #10
Thanks guys.
I bet it was the DOF button for the flash item...I use that all the time to get a DOF preview in live view but didnt realize it had dual functionality - I could easily see myself touching that button by mistake without realizing it.
Ill play with it for another week or two to see if its just me on the underexposure issue and it sounds like its a normal thing to see noise in the red channel when pushing at those ISO's - Ill continue ETTR to avoid this.
So, that just leaves the CF card - Ill try reformatting and see if the issue persists.
Thanks for the info everyone!
Buy & Sell Feedback
mugenpowr
Dec 27, 2011 14:37 |  #11
If the reformatting doesn't work I would suggest testing that card in another body if you have one. Also make sure the pins are not bent in your new camera. This can cause errors in your card. Otherwise I would just use a new card.
1DS Mark III, 5D Mark III, Sony A7RII, Olympus OM-D E-M1, Olympus E-P5
24-70L II, 70-200L, 100L, Contax N85
tzalman
Fatal attraction.
Dec 27, 2011 16:47 |  #12
It is very easy to test your camera to see if it is exposing jpgs properly. Shoot an evenly lit blank wall, a cloudless sky, a sheet of paper that fills the frame, etc. Shoot Av or Tv with 0 EC or M with the needle centered. Now check the Luminance histogram. The spike should be slightly left of center - at about 40 on a scale of 0 to 100 from left to right. [40 because the camera is calibrated to 13% which after jpg processing becomes 40%] Anything from 35 to 45 would be within the +/- 1/3 stop tolerance.
Elie / אלי
1,910 views & 0 likes for this thread, 9 members have posted to it.
1039 guests, 107 members online
