jeffbox wrote in post #13610458
^^ looks like you can't use your hotshoe flash using that setup : / I guess it depends on your needs.
I do not think that it HAS to be in the hotshoe to operate. It is more than likely just a place to place it so it is not dangling by the cord.
The Yongnuo Rf 603's are the same way. If you need the hotshoe for a flash, just mount the transceiver someplace else. They work fine not being in the hotshoe.
If your needs include having it work outside, in bright light, then the IR based RC remotes are NOT what you need. If your needs include not having to be out in front of the camera so the remote can see the window on the camera, then the RC remotes are NOT what you need. If you do not what to activate the timer function of your camera so you have to wait at least 2 seconds for the shutter to trip,then the RC remotes are NOT what you need.
