Thread started 28 Dec 2011 (Wednesday) 12:02
5DII speedlight underexposure
MikeinDallas
Joined Jul 2011
Dec 28, 2011 12:02 |  #1
I just got my 5D/II this week.
It has consistently dark speedlight exposures (1.5 - 2 stops)
I have a 420EX and a Yongnuo YN565EX (a 585EX clone except for the master part and only $155. Nice solid feeling/working flash).
Both speedlights work fine on my T2i over the last 6 months in various situations. Never any issue with external flash exposure.
I usually shoot on manual with the speedlights. Sometimes Auto.
I swap speedlights back and forth between the cameras. All the same manual camera settings (tried Auto setting also) & subject. Flash set on E-TTL.
A BIG difference in image exposures of the same subject. T2i fine. 5DII dark.
Trying both speedlights on my new 5D/II consistently are 1.5 - 2 f-stops darker. I have tried resetting the camera factory settings. Gone thru all the menu settings. The Custom function settings. No exposure or flash compensation is set.
Of course if I set flash compensation of 1.5 - 2.0 f/stops the exposure is fine.
Do many others show this issue? Or am I missing something or does just my 5D/II have an issue. (I saw some brief references several years ago from a search)
Any suggestions or insight appreciated.
Return/exchange or get Canon to adjust it?
Regards
Mike in Dallas (external link)
5D/II, T2i, G11
EF 24-105 L; EF 70-300 f4-5.6L; EF 100 f2.8L, EF 85mm f1.8
JakAHearts
Dec 28, 2011 13:48 |  #2
Can you post the histrograms and resulting images? Ive found that the 5D auto LCD looks darker than my Rebel but the resulting images are of the same exposure.
Shane
MikeinDallas
Joined Jul 2011
Dec 28, 2011 14:50 |  #3
JakAHearts wrote in post #13610744 (external link)
will do
Regards
5D/II, T2i, G11
apersson850
Gallery: 35 photos
Dec 28, 2011 17:31 as a reply to  @ MikeinDallas's post |  #4
Yes, the 5D Mark II also has the automatic brightness setting of the rear LCD, so if you are using that it may fool you into thinking your images are something they aren't.
The histogram will tell you the truth.
Anders
JakAHearts
Dec 28, 2011 18:35 |  #5
apersson850 wrote in post #13611795 (external link)
Indeed. Ive seen my images "drop" over a stop by tilting it towards a recessed light. Silly automatic stuff. :lol:
Shane
MikeinDallas
Joined Jul 2011
Jan 01, 2012 10:44 as a reply to  @ JakAHearts's post |  #6
5DII on Auto (no metering selection allowed), 420EX on Auto
RAW image in ACR 6.6 default settings & Lens correction
IMAGE: http://www.michaeladkinsphotography.com/photos/i-PR7PnHK/2/XL/i-PR7PnHK-XL.jpg
Same 420EX on G11, AUTO, RAW, ACR 6.6 default settings & Lens correction
IMAGE: http://www.michaeladkinsphotography.com/photos/i-kp9fNKK/1/XL/i-kp9fNKK-XL.jpg
Regards
5D/II, T2i, G11
booja
Jan 01, 2012 11:37 |  #7
Set the flash metering to average instead of evaluative. I noticed i usually get "brighter" pics with the 5d2 like this.
First make sure you fec is in the middle or at 0
ejenner
Gallery: 98 photos
Joined Nov 2011
Jan 01, 2012 11:45 as a reply to  @ booja's post |  #8
The LCD can be misleading for sure, but I do use +2/3 - +1 1/3 compensation in matrix metering mode with a flash.
Actually I find I generally need positive compensation with the 5DII. Part of it might be that the ISO values are 'cheated' (i.e. higher than they should be) by 2/3 stop.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
MikeinDallas
Joined Jul 2011
Jan 08, 2012 10:42 |  #9
Used the 5DII MENU: External speedlight control (new camera, for the first time). Went back and forth between average & evaluative metering as a test. No other changes from my initial test pics. All seems normal now with other changes. All direct flash exposures are decent. Bounce light tests were exposed ok also. I can't explain why all is OK now. But a good thing! Never-mind.
Regards
5D/II, T2i, G11
Mark-B
Jan 08, 2012 10:50 |  #10
Did you notice that the 5D shot is at ISO 400 and the G11 shot is at ISO 800? Big difference in sensitivity to the light from the flash between those two settings.
Mark-B
msbphoto.comexternal link
Lisa
"At least once a day"
Jan 08, 2012 10:54 |  #11
Mark-B wrote in post #13667695 (external link)
Yep,I would try it on matching iso settings.
Gear (full list)
Canon 6D & 60D
Photobucket (external link)
nathancarter
Gallery: 32 photos
Jan 08, 2012 11:08 |  #12
In the shot you posted, it's going to underexpose to try to preserve the highlights on that reflective surface in the center of the photo - especially if you're using a metering mode that gives more importance to the center of the photo (evaluative or spot).
In a shot where you're not blowing the highlights/reflections with the flash, I suspect it would work just fine.
dpds68
Jan 08, 2012 11:15 |  #13
Your G11 Shot was also at f3.5 1/15 vs f4 1/160
Gripped Canon 7D,20D,XT / Tamron 17-50mm 2.8, Canon 85mm f1.8 , 70-200 2.8L,EF50mm1.8 II,Sigma 150-500mm OS, Sigma 105mm 2.8 Macro, Sigma 10-20mm 4-5.6
Vivitar285Hv x2,Canon430EX,Nissin Di866,CTR-301P Triggers,
http://www.flickr.com/​photos/dpds68/ (external link)
SeanH
Jan 08, 2012 11:39 as a reply to  @ dpds68's post |  #14
One thing I've learned buying almost every Canon camera from the 10D on is none of them are exactly the same.
I also learned a long ago that FEC is a must on just about every body. However 2 stops does seem excessive. My norm is +2/3 - 1 2/3......depending on subject & distance.
Bottom line is all cameras have their sweet spots, it's our job to find & learn to work with them.......IMO.
7D ......waiting on the 5D3
10-22, 17-40 4.0 L, 24-70 2.8L, 70-200 2.8L, 2 X 580EX's
MikeinDallas
Joined Jul 2011
Jan 09, 2012 11:58 |  #15
Yes. In that test I just put each camera in AUTO mode
Regards
5D/II, T2i, G11
2,712 views & 0 likes for this thread, 10 members have posted to it.
870 guests, 118 members online
