Stuuk1 wrote in post #13614522
I have searched high and low for this... So please excuse me if I have missed the answer.
First of all, I bought cheap. I wanted a tripod quickly and got the shot I wanted with it.
However, I would like to make the most of my cheap tripod (as I am new to photography and don't want to spend big just yet) and have just one question:
The tripod base I have that screws to the bottom of the camera (400D) has a small black, spring loaded, nob. Its as If the camera it is intended for has a hole in it that the spring loaded nob springs in to so that when you set the camera up in portrait the camera doesn't swing down as if to take a shot of the floor... Only problem being, is that the Canon 400D does not have a hole for this and indeed swings down and points to the floor.
Can anyone advise me how their tripods support their camera when in the portrait position? This way I could attempt to adapt mine.
Also, the screw will not do up tight and will spin. I'm guessing this is because it is cheap and they didn't install a T-Bar type of screw head in to the plastic handle. This doesn't matter though and I will probably remove the handle and screw it by means of pliers or something.
I hope this all makes sense...
Regards,
Stuart
I suspect that spring-loaded pin (about 3/16" diameter, just a little smaller than the tripod screw, right?) is for fixing video cameras in alignment, not for holding your camera in portrait orientation.
If the screw doesn't snug your camera down tightly, it won't do at all well in portrait mode, when the head has to be tilted over on its side. You might see if you can back the tripod mounting screw all the way out and put a washer (may need to be small, depending on how the underside of the head is made) or two between the tripod head platform and the base of the screw, just to force it to let you get things tight.
However, the upshot of all this is why the general recommendation is to not try to go cheap on a tripod. If you're easily seeing these flaws, imagine what else may be problematic that you haven't had a chance to observe yet!
The high end approach is to use Arca-Swiss style quick release plates and compatible clamps on a ball head. Many of us use an "L plate", which has mounting plates on both the bottom and one side of the camera; they're custom made for specific cameras so they fit snugly and won't rotate, and by removing the camera and plate from the clamp, and anchoring the other side of the camera/plate in the clamp, you quickly and easily go from landscape to portrait orientation while keeping the weight over the tripod's head, instead of having to get it off to the side where it can sag. See a demo here
Edit: (link fixed - was simultaneously recommending a new monitor for my father)
