Thread started 29 Dec 2011 (Thursday) 11:36
Flash on a Pole (to light-paint a house)
DwightMcCann
so, what are we talking about?
Dec 29, 2011 11:36 |  #1
I am a fan of the Mike Kelley style of architectural photography and have finally decided to try it out. Mike has a number of YouTube videos. He basically sets his camera on a tripod tethered to his laptop and shoots a number of images during the 'Golden Hour' of the overall scene. He then takes his 'Flash on a Pole' and shots the architectural details with it by walking around with the pole and a trigger in his hand. He triggers the camera from whatever his location and the camera triggers the flash. He uses TT5s and a TT1. He then merges all the images in Photoshop with extensive masking. I wanted to share what I am doing so this first section is the basic flash hardware setup.
I am currently planning on doing a shoot of my own house exterior tonight. I need to learn how much flash to use. It may take several tests. I will also be testing a 1/2 CTO gel to warm the flash to be more consistent with the overall lighting ... I have a little kit for that which I'll post on here when I get to it.
But for now. the basic stuff:
#1 This is the beauty dish I want to try ... I don't think Mike uses a modifier so I may also try just the straight flash. I bought it at Samy's but it has not identification that I can see and I have forgotten the manufacturer.
IMAGE: http://www.dwightmccann.com/Images/BTS/fullsize/FlashOnAPole002-Edit.jpg
#2 This is a 580EX II in the Pocketwizard AC7 (modified by Gary McDuffie, Jr.) The AC7 blocks much of the EMI that limits distance ... I'll find out tonight if it works!
IMAGE: http://www.dwightmccann.com/Images/BTS/fullsize/FlashOnAPole003-Edit.jpg
#3 Here is the unit with the TT5 attached prior to going onto the beauty dish.
IMAGE: http://www.dwightmccann.com/Images/BTS/fullsize/FlashOnAPole004-Edit.jpg
#4 Again, I want to be sure you realize that my AC7's have been modified due to terrible QA by Pocketwizard that let a faulty design get through so that OEM external batteries (like Quantum) wouldn't work and put the head tilt slot on the wrong side.
IMAGE: http://www.dwightmccann.com/Images/BTS/fullsize/FlashOnAPole005-Edit.jpg
#5 I use Quantum SC batteries. I have had the big Turbo 2x2 and others and these are so small and light and fit into almost any pocket that I prefer them ... I guess if I was a wedding shooter with Quantum Trio flashes I would want the bigger batteries. Anyway, external batteries are not needed for this application but I prefer them.
IMAGE: http://www.dwightmccann.com/Images/BTS/fullsize/FlashOnAPole006.jpg
#6 While this setup can easily be done using Pocketwizard Plus II's, etc., I am using the TT5s which require this cable ... pricey!
IMAGE: http://www.dwightmccann.com/Images/BTS/fullsize/FlashOnAPole007-Edit.jpg
#7 The Kacey Pole Adapter is a key component for the beauty dish setup. But you can also use your monopod with the flash mounted to it without the dish. As I say, I'm not even sure the BD is a good idea.
IMAGE: http://www.dwightmccann.com/Images/BTS/fullsize/FlashOnAPole009-Edit.jpg
#8 Here's the setup that goes on the pole:
IMAGE: http://www.dwightmccann.com/Images/BTS/fullsize/FlashOnAPole010-Edit.jpg
I've got another image of the camera that I will post in a reply (I don't think this violates the posting rules for this section.) And when I get some additional images of actual use and results I'll post those up, too
Dwight McCann
Website (external link) - Facebook (external link)
Gear List - Concert FAQ - My Small Studio
DwightMcCann
Dec 29, 2011 11:48 |  #2
Here is the camera setup:
IMAGE: http://www.dwightmccann.com/Images/BTS/fullsize/FlashOnAPole011-Edit.jpg
It turns out that my shorter primes all put me in the street so I will actually be using my 85mm f/1.2L from farther back and up a bit higher. I'll try to remember to get BTS images to add to the thread.
Dwight McCann
tetrode
I am a walking repository of thoroughly useless information
Dec 29, 2011 12:19 as a reply to  @ DwightMcCann's post |  #3
Looking forward to seeing your results, Dwight. Maybe you can work Team Dazzle into the shots.
Might that little BD be the RPS Studio RS-3700?
Dave F.
DwightMcCann
Dec 29, 2011 12:23 |  #4
tetrode wrote in post #13615562 (external link)
Dave F.
I would love to work Team Dazzle into the shots but it is way unlikely! LOL. [It's only a 1% chance at the moment, but I am hoping to establish a relationship with a local gym with a lot of space where I can shoot in return for providing publicity images. If that works out, I will try to setup a "Workout with the Team" shoot ... but it could take a year to get there, if at all.]
The BD could be anything! :-)
At the moment, I'll be happy just to get a few BTS images showing the setup in use.
Dwight McCann
OneJZsupra
Dec 29, 2011 13:17 |  #5
Interested to see how this turns out, you have an interesting set up here.
Gear List | Feed Back | My Site (external link)
YN RF-603 O-ring solution
windpig
Chopped liver
Dec 29, 2011 13:27 |  #6
Dwight
Good post.
I'm curious about your endeavor. Is that AC7 working well?
Go ahead, spin the wheel.
DwightMcCann
Dec 29, 2011 13:35 |  #7
windpig wrote in post #13615930 (external link)
Dwight
Good post.
Thank you. I don't know about the AC7 in this application. I've used them at the casino at about 70' feet. I think this first experiment will be about the same. But since it will be outside and since I'll immediate feedback if it is firing I may just walk up the block and see what soft of distance I get. Again, I'll get BTS pictures as I go along.
Dwight McCann
jro
Dec 29, 2011 19:34 |  #8
looking forward to seeing the results.. thanks for making me aware of this technique!
5D Mark II | 17-40 f4L | 24-105 f4L | 70-200 f4L | Sigma 70-200 f2.8 | Sigma 50 f1.4 | 100 f2.8 macro | 15 f2.8 fisheye
580ex II | Slik 814 CFII + AF2100
For sale: Sigma 30mm f1.4
DwightMcCann
Dec 29, 2011 19:34 |  #9
So I did my first quick test ... and did I learn a lot! First, my fancy gaming/video laptop only lasts about an hour, which really reduced the ability to learn ... I just took some flash shots at 1/4 power and hoped for the best. Next time I will wait until much closer to sundown and bring a portable power pack to extend the life of the battery. I also learned that it is hard to see the screen outdoors so I need to make a shade for it. Anyway, here's the BTS of the setup:
IMAGE: http://www.dwightmccann.com/Images/BTS/fullsize/FlashOnAPole013.jpg
This next shot is just a quick HDR of the house to give me a baseline from which to consider changes.
IMAGE: http://www.dwightmccann.com/Images/BTS/fullsize/FlashOnAPole017_HDR.jpg
And here's a shot of me using the flash. Next time I will try without the beauty dish ... it needs to be much more focused. I will also add the 1/2 CTO gel to warm the light. I also know I need to wait for it to get darker.
IMAGE: http://www.dwightmccann.com/Images/BTS/fullsize/FlashOnAPole039.jpg
Since I couldn't see the images and since I was alone I didn't go inside and flash the windows or even wait for it to get dark enough to see the lights inside. This was quite enough to learn in the first go ... I am very pleased with my efforts and expect the next test will include my shooting collaborator, Gary McDuffie, Jr.
I'm also open to any thoughts or suggestions but I think I know what comes in the next test. I will move the truck, close the garage door and hope my wife doesn't wait too long to store the Santa!
Dwight McCann
waterrockets
Joined Jun 2010
Dec 30, 2011 08:18 |  #10
Looking forward to the next steps, thanks for sharing.
FWIW: I'd change the light bulbs and move the hose too. Center that flower pot on the 2nd floor. I wonder if you might get a better silhouette by shooting from further to your right, to cover the house behind. This would also help with the slight obscuring of the window by the front door, and highlight the landscaping on that end of the house vs. the boring garage doors and driveway. To your right is also downhill, so you'll probably have to raise the tripod to stay above the entry sidewalk. Just a thought -- you might see what it looks like from over there.
1D MkIV | 1D MkIII | 550D w/grip & ML| EF 70-200mm f2.8L| EF 24-105mm f4L IS | Canon EF 100-400mm f/4.5-5.6L IS | Samyang 14mm f/2.8 IF ED UMC | 430EXii | EF 50mm f1.8
DwightMcCann
Dec 30, 2011 10:21 |  #11
waterrockets wrote in post #13619729 (external link)
WONDERFUL suggestions that I will implement ... but at the moment I just trying to get the lighting technique! :-)
Dwight McCann
jro
Dec 30, 2011 13:41 |  #12
Seems like a good first effort :D I'm missing why the laptop is so important ? Are you trying to compose/mask these in real time? I think you already mentioned the next steps of progression.. wait till it's darker, you're still fighting the sun too muchj :) Turn lights on inside or flash inside. Craziest part is how when you use the light on a stick you can suddenly see the car in the garage!
DwightMcCann
Dec 30, 2011 14:22 |  #13
jro wrote in post #13621227 (external link)
Yes, yes! :-) The laptop is important because I don't know how much flash to use. Yes, I need to wait for darker to use flash but want to capture some Golden Hour house shots, too.
I figured this would be a steep learning curve ... particularly since I've not been a big location shooter. But I have time, plenty of time to work it out. Although at this point it will likely wait until after the new year as I have paying commitments and my day job for two more months. :-)
Dwight McCann
dmward
Gallery: 29 photos
Dec 30, 2011 14:57 |  #14
Did you look at the video on his blog site?
He uses the tethered MacBook Pro to confirm lighting as he goes along. It looks like the flash is manual which it seems would be required for this kind of "painting".
Also, he says that a single shoot will be 90 minutes to 2 hours and as many as 300 images.
Back in the film days, when I had to shoot a building I would read the light in the building with a meter, then start the shoot when the light outside was the same with an incident meter. Then do additional shots as it got darker.
The light painting with the speedlite is an added benefit.
Einstein or other monolight would probably work as well not sure if its necessary for power maybe coverage though.
Red ­ Tie ­ Photography
Dec 30, 2011 15:07 |  #15
Slightly off topic, but instead of the Mr. LongArm, have you considered going something like this?
http://www.amazon.com …7&creativeASIN=​B00192AAC6 (external link)
I saw it here, and am building mine now. The only thing is, I only say the small one at Home Depot.
http://pixsylated.com …05/longarm-and-metalhead/ (external link)
Bryan
Gear List (external link)
San Diego Wedding Photography - Red Tie Photography (external link)
Red Tie Photography Blog (external link)
9,579 views & 0 likes for this thread, 13 members have posted to it.
1545 guests, 135 members online
