Thread started 30 Dec 2011 (Friday) 10:22
Help with setting up macro setup
matej9o
Joined Dec 2011
Dec 30, 2011 10:22 |  #1
Hi. I've just purchased 5d mkII and 24-105 lens, and I am curious what are 24-105 macro possibilities with extension tubes ?
Before I used 450d + 18-55 + reversed canon 50mm f1,4 FD and I got some pretty results with that:
IMAGE: http://www.pohrani.com/f/23/6I/1H85KTab/mg0766.jpg
I believe that now will be pretty hard to reverse some old FD lens on 24-105, because 24-105 lens diameter is 77mm and on FD is around 52mm. I think that combination will give me lot of vignettes ?
I am looking for some cheap macro options so if you can help me with the setup I will be very grateful.
Also how is 70-200 f4 IS combined with extension tube ? Can someone post some results with 70-200 or 24-105 with extension tubes ?
Canon 5d mkII + 24-105 f/4 IS + 70-200 f/2,8 IS II, 50mm f/1.8 + 580 EXII
Facebook fan page (external link)
javid7
Joined Jun 2011
Jan 02, 2012 04:23 |  #2
I'm using reverse 18-55 on APSC, its unbelievable macro lens.
If you can't use EFs on 5D I think best choice is reverse analog lenses with canon reverse mount and step up ring.
some analog and old lenses are very sharp. you need a wide range like 24mm for reverse.
using 70-200 with Ext Tube is not bad idea but yours is f4 and I think its not good .
امیر_______________
6D, 100mm IS, 50f/1.4
matej9o
Joined Dec 2011
Jan 03, 2012 05:25 |  #3
javid7 wrote in post #13632781 (external link)
Thank you for your response. I am interested in whether there will be any vignetting with the reverse 24mm and how much magnification will be ? Do you have any recommendation for the lens?
javid7
Joined Jun 2011
Jan 07, 2012 06:31 |  #4
Sorry for late answer, 24mm is very good lens for reverse I have not it but you can found many samples with 24mm reversed on the net.if you have and old 24mm with manual aperture control, just start and you will surprise. I guess you will got 3:1 magnification on 24mm.
امیر_______________
4,054 views & 0 likes for this thread, 2 members have posted to it.
Latest registered member is ahmed0essam
1465 guests, 171 members online
