Thread started 02 Jan 2012 (Monday) 13:22
Remote flash with extender
Billginthekeys
Billy the kid
Joined Nov 2005
Jan 02, 2012 13:22 |  #1
I owned a better beamer flash extender a few years back, and lost the lens, anyway now that I have my 500mm I am considering picking one up, and have this idea to mount my 580EX on a seperate tripod with a better beamer, and pick up a ST-E2 to set it off remotely.
I would use it coupled with the 500mm for prefocused setups such as hummingbirds, and think having the fill flash hit at an off angle from the camera could create a nice look, with less of a "this picture has flash" look to it. Anyone here tried a similar setup with any success or lack thereof?
Mr. the Kid.
Go Canes!
My Gallery (external link)My Gear
what the L. just go for it.
Kevin ­ Hall
Jan 02, 2012 13:59 |  #2
It's the way to go for more than just hummingbirds - I've been setting up like this since Feb 2010 for all of my bird shots.
This Downy Woodpecker is the latest with a 43" umbrella.
You can use the ST-E2, that is how I started out, but you will quickly hit the wall of it's limitations outdoors. Your range will be restricted to about 30 feet or so, fine for the birds you are shooting but no good if you want to position a second flash to light that distant background.
Strong sunlight can kill your infrared signal - at times, shooting with the Canon system can be fickle at best and broken at worst when used outdoors.
The ST-E2, being infrared, requires line of sight between your camera and each flash. Such things as a photo blind and light modifiers like umbrellas can block the signal.
The ST-E2 is great for indoor settings where the signal can bounce around a room but for outdoor jobs a radio trigger is a much better option.
Given the close distance you can set your flash to your subject you will find that a better beamer is not necessary.
“By reading this message you are denying its existence and implying consent.”
Billginthekeys
Billy the kid
Joined Nov 2005
Jan 02, 2012 14:01 |  #3
Thanks for the advice, and lovely shots. Very good points on the 30' limit and trouble with IR. What brand/model radio trigger system do you use? I am one step above absolutely igornant when it comes to flash photography and fully admit it.
Mr. the Kid.
Go Canes!
Kevin ­ Hall
Jan 02, 2012 16:52 |  #4
I'm using Pocket Wizard Flex transceivers but there are lots of alternatives out there. I see good things about Phottix, Radio Poppers, Pixel King - there are plenty of manual flash options and more brands are offering ETTL devices all the time.
If you want to learn about this type of lighting spend some time on the Strobist blog and at the Strobist group on Flickr. It's going to be mostly models, weddings, and products but the concepts cross over.
Most people are not using this type of lighting for wildlife outside of hummingbird set-ups and the ones who are do not talk about it much. They want you to spend money on their workshops instead.
Billginthekeys
Billy the kid
Joined Nov 2005
Jan 02, 2012 17:00 |  #5
So these are what I would need?:
http://www.bhphotovide​o.com …nsceiver_Radio_​Slave.html (external link)
http://www.bhphotovide​o.com …io_Slave_Transm​itter.html (external link)
Does the slave mount directly to a tripod thread?
Mr. the Kid.
Go Canes!
Kevin ­ Hall
Jan 02, 2012 17:33 |  #6
I have a set of three of the Flex TT5 transceivers (one per flash and one to transmit from the camera) and an AC3 Zone Controller (external link). (Let's you control three sets of flashes at different outputs)
The mini TT1 is nice and cheaper but it takes a special CR-2450 lithium battery while the TT5 uses two AA batteries - for me the TT5 is more convenient because of this.
The TT5 has a standard 1/4"-20 socket for connection to your light stand. I have an older 550EX that I use for lighting the background or providing rim light on the bird. That goes on a 366B light stand (external link) by way of a Giottos mini ball head (external link).
For the main light I use a 580EX II on another 366B with an umbrella swivel adapter (external link) and a collapsible umbrella (external link).
If you end up using an umbrella or any kind of light modifier that can catch wind make sure you put about 20 pounds of weight on the base of your stand or stake down the legs really well - shouldn't tempt fate when you attach your flash and trigger to a kite.
PIX-R-IT
Joined Dec 2011
Jan 02, 2012 18:18 |  #7
Those are some real beauties Kevin !
Bananapie
Joined Jun 2011
Jan 03, 2012 04:27 |  #8
Yeah, Kevin....your shots blow me away (as usual).
Billginthekeys
Billy the kid
Joined Nov 2005
Jan 03, 2012 07:57 |  #9
Thanks Kevin, I will have to do my homework on it before my next trip.
Mr. the Kid.
Go Canes!
Kevin ­ Hall
Jan 03, 2012 08:02 |  #10
Thanks guys, it's going on 17 years for me this spring - I may have learned a thing or two along the way.
Thank God it's digital and not film though, I'd need a roll off for what I weed out. ;)
1,880 views & 0 likes for this thread, 4 members have posted to it.
650 guests, 125 members online
