Thread started 03 Jan 2012 (Tuesday) 12:09
F-stop Loka Review:
jacobsen1
Jan 03, 2012 12:09 |  #1
this is a repost of my blog review, but I figured you guys might like to see it here instead of clicking through (external link)...
video review: http://www.youtube.com​/watch?v=8q7DRb9zNu0&h​d=1 (external link)
The f-stop loka is a hell of a backpack. That’s ignoring it’s ability to haul cameras. This is just one hell of a great backpack first, then it has this awesome system to add inserts into it specifically designed for cameras (f-stop calls these “ICU”s or internal camera units). I’ll get to that more in a bit. For this review, I didn’t want to just do a review based on my initial impressions and some light use, I really wanted to spend some time with the bag and get to know it. For that reason it’s taken me two months to get what I consider to be enough time with the bag to really know it, and know how it works. I’ve been using this bag as my daily photo bag for 2 months now going to work, I’ve taken it on landscape adventures every weekend since I got it, and then this past weekend I hiked Tuckerman’s Ravine with it and finally did my video review (make sure you click the HD link in the bottom right corner above when you watch the video).
Here you can see what fits inside my loka with a medium shallow insert:
Now, first impressions are that it’s a really well built and thought out bag. There are a LOT of really nice details in here. The bag is also quite light, especially w/o an insert (even if you order them together, they’ll come in 2 separate bags so you’ll initially pick up the loka w/o anything in it). Once you get the bag out of it’s bag (yes they come in protective bags) you then get to your insert. Their inserts, or ICUs are well built (but maybe not quite as nice as thinktanks) and come in a TON of sizes (click here to see the list). I went with a medium “shallow” ICU. Shallow is the size for DSLRs w/o grips, “pro” is for 1 series canons or gripped bodies, then “micro” is for EVIL type cameras. Medium gives me enough space for what I landscape with. Large makes it more of a photo bag but I don’t need that much space. I have been thinking of adding a shallow small to my setup though, since it can sit above the medium to allow use of both when you need it, or downsizing when I only want a really tiny kit. The short version about the ICUs though is they make the size you need, you just have to decide what you need exactly and pick it out on their site. This took me about a week to do myself. ;) F-stop also has a new line of accessory bags that work with the molle loops on the side of the bag as well as one the left belt strap. Check them out here.
Let’s get into the details. The harness has some of the best foam I’ve seen. Very soft. It feels like neoprene (it could be). The harness itself is a tad short for me with HEAVY loads. With <40lb in my bag it’s fine, but with >40 (my pack with gear and water and skis and boots was pushing 60lbs) I can’t quite get all the weight off my shoulders and onto my hips. I have a walk around for this though where I just add in some additional webbing to the shoulder straps, not idea, but it works. Initially I felt the webbing size was a bit small on the shoulder straps (it’s ~1″) but it’s strong enough to carry the load and I’m sure it saves a few grams which is never a bad thing. The bag also has a nice internal sleeve for a water bladder or snow tools. There’s a velcro loop above it to hold your bladder up. There’s also a port on the side for your “straw” to go out to your right shoulder strap. This pocket also works well for laptops in non back-country mode or shovels/probes/snow tools if you don’t use a bladder. There’s an external pocket with a vertical zipper on center for your shovel blade as well. This was a tad bit tight for my lifelink blade, but it goes in w/o any force and you can get it out in a hurry, it’s just a bit of a geometry quiz getting it in (it WAS 5am in a cold parking lot with no sleep in ~22 hours though ;) ). The handle, snow saw and probe all fit in along side the ICU. My lifelink snowsaw JUST fits in, I actually have to flex it a bit to fit but it works well for me. Skis slide in the side with a solid strap at the bottom and one with a buckle up top. Skis cover the molle loops on the side when there, but that’s life with skis in an A-frame. I prefer diagonal carry myself which can be done with some additional “gatekeeper” straps they have on their site. They also offer a rain cover for an additional $20 (IMHO that should be included, but the price is fair I guess). The same gatekeeper straps can go on the top or bottom of the bag, which means you have options to add things to your bag (tropod, sleeping bag, tent, skis etc) on the top, or bottom (via gatekeepers) or the sides and back using the straps provided. A snowboard would also work on the back.
Here you can see how I’ve been shooting with this bag to avoid getting it dirty:
Final Thoughts: The loka is a backpack first and a camera bag second. Don’t take this to mean it’s not a great camera bag, in fact it’s fantastic, it’s just that it’s meant to be more than that. If you want to carry JUST camera gear in a backpack all day everyday, this will work, but it’s not the point. That’s what thinktank and lowepro are making bags for. If you’re going outside, on less traveled routes, hiking or skiing or doing anything else fun, that’s where the loka shines. It’s just like the backpack you have and love now, only it adds in the option of adding in ICUs for your camera. This makes it an amazing camera bag designed to go anywhere with you. No, it’s not perfect, but it’s closer than anything else on the market. If you’re on the fence between this and say the thinktank or lowepro I mentioned, get the others, you dont’ need this bag. If you’re on the fence between this or a burton or dakine photo bag (you know who you are) then this is the EXACT bag you need. Don’t balk at the price, it’s worth it. The bag also takes their new line of dakota accessories (modular pouches) or bags from thinktank or lowepro etc. There are also straps on all sides of the bag, back, top, bottom and both sides (some require additional “gatekeeper” straps). This allows you to customize this bag and add a lot of extra goodies on the outside should you need more room but don’t want to upgrade the size of the backpack itself. If you’re going outside to do fun things and bring a camera along with you, this is the bag for you (or at least the system).
Pros:
lightweight pack
ICUs come in different sizes to fit your exact needs
space in the bag for NON photo gear
space for a water bladder and snow tools
has an optional rain cover
has a great harness (padding is amazing)
awesome rubber coating on the bottom
straps on the back and sides for skis, tripods or anything else you need
provisions for gatekeeper straps on the top and bottom for adding even more gear
molle loops on the sides and left belt strap for adding accessory bags (f-stops dakotas or thinktank etc modular bags)
Cons:
Harness is a tad short if you’re 6’4″
rain cover is $20 extra
padding/ICU not quite as nice as thinktanks or lowepros, but it works and is lighter
expensive (but worth it!)
I wish the rubber coating was also on the back
My Gear List
my sites:
benjacobsenphoto.com (external link) | newschoolofphotography​.com (external link)
GND buyers FAQ
FOR SALE: 5Dii RRS L-bracket, 430II, 12mm macro tube PM ME!
TijmenDal
Jun 14, 2012 17:52 |  #2
Hi Ben,
Great review! You're 6'4 I take it? I'm 6'5 myself, though my torso isn't very long. My legs are relatively very long. I'm strongly debating if I should get the Loka, but not sure yet. Might just make use of the money-back guarantee I guess...
//Tijmen
http://www.flickr.com/​photos/tijmendalexternal link
Gear
______________
flickrexternal link
_____________
cmoy
Gallery: 94 photos
Jun 15, 2012 08:41 as a reply to  @ TijmenDal's post |  #3
GREAT review Ben!
Chris
website (external link)
ciscopro2000
Jun 15, 2012 12:53 |  #4
Awesome review once again Ben. I love reading your write ups. I would love to get one of these, but the price is hard to swallow. :-)
Judsonzhao
Joined Feb 2012
Jul 05, 2012 22:47 |  #5
Like the bag, white is awesome
Fly me away.
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Jul 06, 2012 00:51 |  #6
Is there a way to see it on your Back ? Thanks
Doc Klepper in the USA
I
TijmenDal
Jul 06, 2012 04:48 |  #7
Ok. I tried both the Tilopa and Loka, but couldn't justify having both, so I send the Loka back. While initally I thought the Loka was really the bag that fit my needs better for everyday use, I kept the Tilopa. They're very similar in height. The Tilopa is a tad bit wider, but much deeper than the Loka. That's where the difference in volume comes from. Like Dan Carr pointed out in his review(s), it's nicer to have your center of gravity closer to your body (as is the case with the Loka).
Now, why would I choose the Tilopa over the Loka you might ask?
Few things:
- The Tilopa has MUCH nicer straps and padding
- It has a laptop compartment
- Feels much sturdier/rugged (ie. durable)
- You can size it down REALLY well by just pulling the straps on the bag tight. After I do that, the difference in depth with the Loka is next to nothing
- It's much bigger. I want to use it for camping trips/overnight trips as well, and then the extra space is just necessary.
- The Loka had a shovel compartment in the front. As an avid backcountry skier, this is where my bag will see the most use. The compartment is too small for my shovel. It fits something like the Ortovox Pro (which, despites it's name is a guarantee your buried body will die, because the shovel sucks ball), which has a really small shovel blade. No use for a pocket like that, because that really is the only use you have for the pocket. The Tilopa is advertised to have a shovel pocket (that one is too small too), but you can use it for storing other stuff.
Like I said: it thought the Loka was the perfect every-day use bag, but that is still pretty limited as the Tilopa can be just that and more if you use the capacity to it's full potential.
//Tijmen
Gear
______________
flickrexternal link
_____________
jacobsen1
Jul 06, 2012 07:01 |  #8
rklepper wrote in post #14677162 (external link)
did you watch the video in the original post?
TijmenDal wrote in post #14677577 (external link)
Few things:
I've recently made the opposite decision because I also couldn't justify both... For me, I actually like the neoprene on the loka better. It's not as thick, but it feels better to me.
no offense, but why on earth would you want to bring a laptop in a bag like this? This was one of the big reasons I went to the loka. No BS padding along for the ride every time I go BC. That's a water bladder sleeve IMHO, not a laptop one, why do we need padding there? plus, if I bring a laptop along when NOT skiing with this bag, it's in it's own padded bag anyway.
were they the same design cycle? IMHO, the loka wins there due to it's rubber bottom.
agreed except for that damn laptop padding
agreed, and this is what's tough for me. I day BC ski far more than I camp. I also use a chest bag a lot when I use this bag so it gets ALL the camera gear out of it giving me just enough room for longer trips with gatekeepers... but that was a major consideration
my lifelink juuuuuuust fits in. It's actually a PITA to get in, but I can grab/rip/pull it out fast as needed. Luckily. And I agree, it IS tighter than needed since anything that does fit only fits just barely.
in the end, that laptop padding really annoyed me. It's a backcountry skiing backpack. Who the hell takes a laptop with them BC? And it takes some space out of the bag and adds (marginal) weight. That and since I just use it as ONLY a photo bag all summer I like that there's not a lot of extra material on it when I'm doing that.
but it's what works for each of us that matters. Having the choice is awesome. I only wrote out my reasons so people can see a different perspective if they're trying to make the same choice. :)
My Gear List
my sites:
GND buyers FAQ
6,760 views & 0 likes for this thread, 6 members have posted to it.
F-stop Loka Review:
973 guests, 107 members online
