Thread started 03 Jan 2012 (Tuesday) 16:46
Lens test?
sosaysmorvant
Joined May 2011
Jan 03, 2012 16:46 |  #1
Is there a certain protocol to follow when buying a used lens to make sure it is functioning properly? I've bought several items off of craigslist without issue, but I am hesitant to purchase a quality lens due to the dollar investment you have to make.
In other words, would a visual inspection and firing a couple pictures with a lens be enough to warrant a purchase? I'm looking at a 24-105L lens for about $700. I'd be very unhappy if I got scammed.
Opinions and advice are greatly appreciated!
wimg
Jan 03, 2012 17:23 |  #2
There are many ways to test a lens, and it often also depends on experience.
Here is a page with links to get you going:
http://www.sciencebudd​ies.org …hoto_p001.shtml​?from=Home (external link)
Personally, I'd do a few quick shootouts directed at a brick wall, parallel to it, and check if the resolution falls of equally towards the edges and corners, and I'll do that at different apertures (and FLs of course). I'll also check AF by aiming at the edge of a brick in the same wall, but at 45 degrees, again at different FLS.
I'd also make a few real life type shots, just to see how those look overall.
And before doing these tests, I'd make sure I know as much as possible about the lens in question, by studying reviews, and noting what to expect.
HTH, kind regards, Wim
jrbdmb
Joined May 2011
Jan 03, 2012 17:35 |  #3
Here's a nice article on the subject:
http://www.lensrentals​.com …010/11/how-to-test-a-lens (external link)
Tools: 70D, 10-22, Tamron 24-70 VC, 70-300L, 135 f2L
rick_reno
Jan 03, 2012 19:15 |  #4
You probably won't be scammed.
1,108 views & 0 likes for this thread, 4 members have posted to it.
Lens test?
1701 guests, 140 members online
