Thread started 05 Jan 2012 (Thursday) 07:26
spraying prints
paddler4
Jan 05, 2012 07:26 |  #1
I have seen several references to spraying a protective coat on prints. E.g., Inkpress sells a spray, and Moab recommends one for one of its papers (I forget which). I have never used one. Any experience with pros or cons? I use a dye-based printer (Pixma Pro 9000 II) if that is relevant.
thanks
Check out my photos at http://dkoretz.smugmug​.com (external link)
Jon ­ Tree
Jan 05, 2012 07:43 |  #2
I wouldn't recommend spraying a liquid laminate on top of dye based ink as the ink is not water resistant and will run. Ideally you should be using pigment or latex based inks which are water resistant and offer greater fade resistance. I have had mixed results with liquid laminates and so far have found that clearstar gives the best results. If you can try to avoid applying laminate with a hand roller as it is very easy to create bubbles and streaks, I find using a spraygun gives much better results :) I guess the other option would be to look at a hot press.
Wilt
Jan 05, 2012 10:17 |  #3
Using the acrylic spray prevents most of the ink from running. Products like Krylon Crystal Clear Acrylic are acrylic based.
While I, personally, have not used Krylon on inkjet prints, I certainly have experience in spraying Krylon protective sprays on conventional photographic prints, and my father used to use it on his charcoal charictures.
From Mastering Digital Printing by Harald Johnson, "Coating brands that have developed followings with digital printers include the following: Clearstar ClearShield and ClearJet (clearstarcorp.com) Superfrog Frog Juice (superfrog.com) Lyson Print Guard (Lyson.com), Bulldog Ultra Coating (bulldogproducts.com) Liquitex Solivar varnish, Krylon Crystal Clear, UV-CLear acrylic sprays, and Sureguard (perfectiondistruibuti​ng.com), and Lacquer-Mat (Lacquer-mat.com) photo lacquers."
paddler4
Jan 05, 2012 11:47 |  #4
thanks folks
Picture ­ North ­ Carolina
Gaaaaa! DOH!! Oops!
Jan 06, 2012 10:24 as a reply to  @ paddler4's post |  #5
I've looked into this myself recently, and sought advice. Pretty much everybody seems to recommend the Premier print spray.
Edit: (But I am using pigment inks).
Website (external link) |
ssim
Joined Apr 2003
Jan 06, 2012 13:46 as a reply to  @ Picture North Carolina's post |  #6
My lab offers this and I did try myself a long time ago and did a crap job of it. So if I know I want this I spend the small amount they charge. I'm not sure of the exact product the apply.
René ­ Damkot
Jan 06, 2012 16:09 |  #7
And CmdShift4, press space to take a screenshot of the window the mouse is over…
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
DAMphyne
"the more I post, the less accurate..."
Joined Feb 2003
Jan 07, 2012 08:31 |  #8
René Damkot wrote in post #13659136 (external link)
Huh?:confused:
David
Digital set me free
"Welcome Seeker! Now, don't feel alone here in the New Age, because there's a seeker born every minute.";)
www.damphyne.com (external link)
René ­ Damkot
Jan 07, 2012 15:29 |  #9
Huh? How did that post end up in this thread???
It was supposed to be a reply here: https://photography-on-the.net …p?p=13658360#po​st13658360
Nevermind it then…
tonylong
...winded
Gallery: 60 photos
Jan 07, 2012 15:56 |  #10
René Damkot wrote in post #13664072 (external link)
Nevermind it then…
Heh! That there's funny, René:)!
Tony
Gaaaaa! DOH!! Oops!
Jan 07, 2012 16:16 |  #11
Nevermind it then…
tonylong wrote in post #13664209 (external link)
Probably attributed to the fact that that slave-driving Pekka has these poor guys working 48-hour shifts with no sleep. But I hear the pay, benefits, and retirement package are great! ;) :lol: :lol:
2,934 views & 0 likes for this thread, 8 members have posted to it.
spraying prints
1458 guests, 128 members online
