Thread started 15 Nov 2005 (Tuesday) 14:34
Canon FD 50mm f/1,8 with reverse ring on 20D. Does it work?
tiziano
Nov 15, 2005 14:34 |  #1
Hi,
One quick question: will a Canon FD 50mm f/1,8 with reverse ring work on a 20D for Macro pics?
Thanks!
Tiziano
Gear list
JonathanS
Nov 15, 2005 14:49 |  #2
What kind of reversing ring? Do you mean that you want to put the FD 50 reversed on top of another lens or just reversed onto the body? Reversed on top of another lens is easy, but I have not seen many reverse onto the body adapters. When it comes to reversing though, it really does not matter what kind it is, only that it has the proper front filter screw diameter. In most cases, there will be no electrical connection from the body to the lens, so in fact the older lenses (with manually selectable f-stops) are better.
Canon Digital Rebel 300D (unDutchables 0.2.3)
Canon RebelG 500N
Canon 17-40 F/4L
Canon
EF-S 18-55 | Canon EF 28-80 USM | Sigma 70-300 Macro Super II
Canon 430EX | Canon Speedlight 155A
Canon IP5200
http://photobucket.com​/albums/a14/jonstickle​s/ (external link)
tiziano
Nov 15, 2005 14:53 as a reply to  @ JonathanS's post |  #3
That's exactly why I have chosen the FD lens. I want to use the reverse ring to connect it directly to the camera, using the manual aperture on the lens, and shutter speed on the camera. Will the 20D electronic let me do it?
Tiziano
Gear list
JonathanS
Nov 15, 2005 15:01 as a reply to  @ tiziano's post |  #4
Yes, with the FD lens, and with most reversing adapters, there is no electronic connection to the camera, which means you will have to set your aperture manually. The camera will be able to give you your shutter speed based on that automatically though, in any case, which adapter are you planning on using? I have been looking for a while but have not found one I like.
Canon RebelG 500N
Canon 17-40 F/4L
Canon
Canon IP5200
tiziano
Nov 15, 2005 15:06 as a reply to  @ JonathanS's post |  #5
I was thinking to use this adapter ring:
http://cgi.ebay.it …ame=STRK%3AMEWA​%3AIT&rd=1 (external link)
Tiziano
Gear list
JonathanS
Nov 15, 2005 15:15 as a reply to  @ tiziano's post |  #6
thanks, have seen these before. When you get it (if not already) if you could let me know how it works I would appreciate it.
Canon RebelG 500N
Canon 17-40 F/4L
Canon
Canon IP5200
tiziano
Nov 15, 2005 15:34 as a reply to  @ JonathanS's post |  #7
I will, when I'll get it. First I need to buy the lens. The one I was looking at on ebay, I missed it 10 minutes ago, for 8 secons and 50 cents! :o
Tiziano
Gear list
Jon ­ Foster
is it safe?
Nov 15, 2005 15:42 |  #8
I'd like to know how well it works too. I was going to make one but haven't had the time yet.
Jon.
I shoot with a Little Canon
Check out my photos @ PBase.com (external link) & ModelMayhem.com (external link)
JonathanS
Nov 15, 2005 15:58 as a reply to  @ Jon Foster's post |  #9
yeah, that happens a whole lot to me too, I hate it. But, the next time I saw one, I bid on that too and won, and ended up paying less anyhow.
Canon RebelG 500N
Canon 17-40 F/4L
Canon
Canon IP5200
Jon ­ Foster
is it safe?
Nov 15, 2005 16:09 |  #10
Dont' forget about the good old local pawn shops. They always have older cheap SLR stuff.
Jon.
tiziano
Nov 15, 2005 16:16 as a reply to  @ Jon Foster's post |  #11
Jon.
Thanks Jon! I'll give a try there as well.
Tiziano
Gear list
Pixel9ine
Nov 16, 2005 17:10 |  #12
That's the exact lens I'm using.. it's pulling double-duty between my AE-1 and A95.... I've just posted some pics to the 'ballpoint pen' thread here..
One question, though: why would one need to stop down the aperture on the reversed lens? Wouldn't that only reduce the image size and cause vignetting? I shoot with the aperture wide open with my fifty, with aperture controlled on the lens attached the body.
Andre B :: gearlist
www.pixel9ineexternal link.com
tiziano
Nov 16, 2005 17:22 as a reply to  @ Pixel9ine's post |  #13
Well, I guess for DOF. I have never shot macro so far (I'll give a try when the adapter I have ordered will be delivered), but, even if you are shooting at a small thing like an insect or a small flower, there may be some situations in which you want a deeper area to be in focus... Anyway you gave me a good idea: first I'll try with my EF 50mm f/1.8 wide open or almost wide open, and, if I feel the need to have more DOF, I'll buy the FD lens.
Thanks!
Tiziano
Gear list
tiziano
Nov 16, 2005 17:30 as a reply to  @ tiziano's post |  #14
By the way, Croesus, your pics are much behind my expectations!
But, now, I am thinking of another thing: will a longer lens, say an 85 mm or 135, work even better when reversed for macro?
Tiziano
Gear list
Pixel9ine
Nov 16, 2005 22:58 as a reply to  @ tiziano's post |  #15
:confused: Umm.. If you mean "beyond expectations," I'll take as a compliment.
I don't know how a longer lens will affect your macro - most people stick to the reversed 50mm lens. If you want a higher magnification, like the 85 or 135mm, mount that on the camera side, and place the 50mm in front.
Stopping down the aperture on the reversed lens won't affect DoF (because the aperture blades are past the focal point of the camera lens), they'll just cut down on the useable area of your image and cause vignetting. Adjust for DoF with aperture of the lens mounted to your camera.
Here's a really good article on the topic:
All You Really Need to Know About Reversed Camera Lenses (external link)
Andre B :: gearlist
5,025 views & 0 likes for this thread, 6 members have posted to it.
1079 guests, 123 members online
