Thread started 05 Jan 2012 (Thursday) 11:57
CPL+stepdown+hood question
jbrackjr
Joined Dec 2011
Jan 05, 2012 11:57 |  #1
Noob question….I have a 10-22 which is 77mm & a 18-200 which is 72mm both with hoods. I know I can use a CPL (77mm) and a stepdown ring for both lenses, but will it work with the hood on the 18-200?
Looks like it should clear the hood, but maybe not... Any other issues with this type of arrangement? I was going to purchase the CPL & B&W Schneider 77-72 but if it won’t work with the hood, I won’t need the ring and will have to buy two CPL's.
Thought I would check before I place the order.
Thanks for your help.
Jim
ben_r_
-POTN's Three legged Support-
Jan 05, 2012 12:59 |  #2
You mean use the 10-22 with a 77mm CPL and the 18-200 with a STEP-UP adapter ring. Yes that will work, but you will not be able to use the hood on the 18-200.
jbrackjr
Joined Dec 2011
Jan 05, 2012 13:42 |  #3
Thanks ben.
So if I understand you correctly, you start at the lens (18-200) and step up to the CPL. I was starting at the CPL and going down to the lens. If I chose to go without the hood, Iwould look to order a male thread 72mm to female thread 77mm ring (step up). Please correct me if I am wrong. Still learning. Thanks again.
Jim
dedsen
Jan 05, 2012 14:33 |  #4
Just remember the you need to get your finger in there somehow to adjust the CPL.
ben_r_
Jan 05, 2012 15:05 |  #5
jbrackjr wrote in post #13652134 (external link)
Thanks ben.
Pick up this one here: LINK (external link)
DerekW
Jan 05, 2012 15:09 |  #6
Would you even be able to rotate the CPL with a hood on?
ben_r_
Jan 05, 2012 15:16 |  #7
DerekW wrote in post #13652619 (external link)
Some of us can, some of us cant it seems. I usually can, and do, depending on how Im shooting. But as others seem to have issues with it, perhaps I have long fingers?
DerekW
Jan 05, 2012 15:36 |  #8
It would just seem easier to adjust to get what your looking for from the side rather than putting your hand in front of the lens, refocusing, and repeat. :)
jbrackjr
Joined Dec 2011
Jan 05, 2012 16:05 |  #9
Ben, thanks for the link.
Not sure if I can do it, but I would like to keep the hood on all the time so I will try it and see if works for me.
Jim
argyle
Jan 05, 2012 16:28 as a reply to  @ jbrackjr's post |  #10
Its good practice to use a hood, but to be honest, its not always necessary depending on the conditions.
You will need what Ben mentioned in Post #2...step-up ring...this will allow you to use the 77mm filter on the smaller diameter lens without getting any vignetting.
Another option is to do what some others have done...use a Dremel or something similar to cut a finger slot in the bottom of the hood...this will let you slip in a finger to adjust the CPL. This is really only needed for deep filters...the petal hood for the 10-22 should be plenty shallow enough for you to get your fingers on the filter. An easier option is to use a collapsible rubber hood that you could thread onto the filter...to adjust the CPL, just simply rotate the outer edge of the hood.
1,178 views & 0 likes for this thread
Latest registered member is miltiades
1012 guests, 303 members online
