Thread started 15 Nov 2005 (Tuesday) 18:27
? about video camera lens compatibility.
scott ­ stokes
Joined May 2004
Nov 15, 2005 18:27 |  #1
i was just looking at the thread about what is your dream lens and they had a linkshowing a canon xl1 with the 1200mm lens,my ? is will the lens from a xl1 video camera work on my 10d.
50d ,50 1.8,420ex,,tameron 19-35,tamron28-75,sigma70-200 2.8,bigma,24-70L
tim
Light Bringer
Nov 15, 2005 19:07 |  #2
Very doubtful, at least without a lot of DIY knowhow to somehow get them together. I suspect the quality would be sub-par for a still camera too.
Jon
Joined Jun 2004
Nov 16, 2005 10:05 |  #3
Also the lenses from the XL1 probably won't cover even an APS-C sensor, even if there's enough back focus on the lens to let it clear the EOS body at infinity.
Jon
Cocker Spaniels
Andy_T
Joined Jan 2003
Nov 16, 2005 10:09 |  #4
No, EF lenses can be used on the XL1 with an adapter, but not vice versa (XL1 has about 5x crop factor)
The 1200 shown in this link is the standard EF 1200/5.6 L lens.
You can use it on your 10D without any problems (other than coming up with about $ 80,000)
Best regards,
Andy
some cameras, some lenses,
and still a lot of things to learn...
(so post processing examples on my images are welcome :D)
If you like the forum, vote for it where it really counts!
CLICK here for the EOS FAQ
CLICK here for the Post Processing FAQ
CLICK here to understand a bit more about BOKEH
Zepher
Joined Nov 2005
Nov 16, 2005 15:39 |  #5
The stock XL1 lens isn't all that good either. The one thing I hate about it is the infinity focus ring, the kind that you can just keep turning and turning.
A lot of people go with the manual Canon lens for the XL1.
Manny Desantos
Intel C2Q Q6600 3.06Ghz, 8GB Ram, 8.1TB, XFX HD5850, Windows 7 Ultimate 64bit, PS CS4 EXT (external link)
Canon 40D, EF 28-70L, 2x Canon XH-A1 HDV, Canon HV30 HDV
❶_______________
DocFrankenstein
Joined Apr 2004
Nov 16, 2005 15:48 as a reply to  @ Zepher's post |  #6
yeah, those are cheaper too
I'd want to have 70-200 mounted on XL1 to film some hawks...
490-1400 f/2.8 is just about right for those birdies. :cool:
National Sarcasm Society. Like we need your support.
scott ­ stokes
Joined May 2004
Nov 16, 2005 17:53 as a reply to  @ DocFrankenstein's post |  #7
thanks for the replies.i figured it would be that way ,i was surprised to here that the lens on those video cameras are not that good,my brother used them to tape hunts for his tv show,and also they have xl2 and some huge JVC camera.thanks scott
Jon
Joined Jun 2004
Nov 17, 2005 10:32 |  #8
They don't have to be that good. Your typical video image is something less than 800x600 resolution. Even going to high-def, you're still looking at much less than a 2 MP image.
Jon
Cocker Spaniels
DocFrankenstein
Joined Apr 2004
Nov 17, 2005 15:51 as a reply to  @ Jon's post |  #9
They have to be better, since the sensor is smaller and the photosites are closer together.
Jon
Joined Jun 2004
Nov 17, 2005 18:27 |  #10
No, with the lower resolution, and smaller sensor they don't have to be as good as an equivalent lens covering a larger area. They're covering the easy part of the frame, after all.
Jon
Cocker Spaniels
DocFrankenstein
Joined Apr 2004
Nov 17, 2005 18:51 as a reply to  @ Jon's post |  #11
There's no "easy" part of the frame anymore because the lens is designed for the sensor specifically.
The pixel density in XL is higher than that in digital cameras. Which one requires lenses with higher resolution?
scott ­ stokes
Joined May 2004
Nov 17, 2005 20:49 as a reply to  @ DocFrankenstein's post |  #12
I got on canons web tonight too see what i could find on this,the video lens are L lens,and it said you could use any of canon 35mm lens and that some thirdparty lens could be with an adapter,but it did not have anything about the other the opposite.i think i will email them.
DocFrankenstein
Joined Apr 2004
Nov 17, 2005 20:57 |  #13
It's impossible to do the opposite.
Zepher
Joined Nov 2005
Nov 18, 2005 10:58 as a reply to  @ DocFrankenstein's post |  #14
Is the pixel density more becuase you mulitply it by 3 since the camera has 3chips?
I'll snap a pic of the XL1's sensor and the lens face today if I go by the studio.
Manny Desantos
❶_______________
Jon
Joined Jun 2004
Nov 18, 2005 11:06 as a reply to  @ DocFrankenstein's post |  #15
If I'm reading B&H's listing correctly, and my math is anything like correct, a sensor site on the XL1s is 72 sq. microns. The 20D has 3504x2336 pixels in 22500x15000 microns, or 41.23 sq. microns/sensor site. Looks like the 20D requires a higher lens resolution to me.
Jon
Cocker Spaniels
1,865 views & 0 likes for this thread, 6 members have posted to it.
2173 guests, 129 members online
