Hi everyone,
I seem to have a re occurring problem that I can't get sorted out. Hopefully someone has an idea or preferably.... a solution!
First my desktop... copy/pasted from dxdiag
System Information
Time of this report: 1/6/2012, 22:53:11
Machine name: COMPUTER1
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.110622-1506)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 08/24/10 17:39:01 Ver: 08.00.15
Processor: AMD Phenom(tm) II X6 1055T Processor (5 CPUs), ~3.3GHz
Memory: 16384MB RAM
Available OS Memory: 16374MB RAM
Page File: 2890MB used, 29857MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
Display Devices
Card name: AMD Radeon HD 6900 Series
Manufacturer: Advanced Micro Devices, Inc.
Chip type: ATI display adapter (0x6719)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_6719&SUBSYS_20101787&REV_00
Display Memory: 1761 MB
Dedicated Memory: 2022 MB
Shared Memory: 3835 MB
Current Mode: 1680 x 1050 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: L226W
Monitor Id: GSM566B
Native Mode: 1680 x 1050(p) (59.883Hz)
Output Type: DVI
Motherboard is a Asus M4A87TD Evo
The problem I seem to be having with my computer seems to be a heating/power issue but that's only my guess
I built this computer about a year and half ago and its been running great since. In the last month or so it just started turning off.
Symptoms are... it will run without fault and then all of a sudden it just completely turns off like as if the power was unplugged. If I press the power button it will not turn back on. I have to reach around to the back of the computer, flip the switch on the power supply itself to off. Flip it back on. Then I can turn the computer back on.
It can run the entire day under load without turning off once. Other days It will run 5 minutes and turn off. More increasingly its been not wanting to turn back on. I will flip the switch. Turn it on, before it even boots out of dos it will shut down again.
This 'sounded' like a over heating issue to me so I replaced the thermal grease yesterday and its still doing the same thing. The case itself is a gaming case with a couple fans on the front, one in the back, and a massive exhaust one on the top. The cpu also has a massive cooler on it that nearly touches the side of the case. Anytime I turn the computer back on and check the temp in bios it reads about 36-40 celsius on the CPU and 29 celsius on the motherboard which doesn't really sound like its too hot
Any suggestions?
Edit: I've also had all the cores unlocked on the cpu since I first got it. I dropped it back down to factory settings a little while ago.
