On my 50D crop body what would be a better choice, Sigma 30mm or 50mm f/1.4 ?
alexxn Senior Member 396 posts Likes: 9 Joined Nov 2011 Location: S Florida More info | Jan 07, 2012 18:29 | #1 On my 50D crop body what would be a better choice, Sigma 30mm or 50mm f/1.4 ? Nikon D4S, D3, Nikkor AF-S 50 f/1.4G, Nikkor AF-S 85 f/1.8G, Nikon AF-S 24-70mm f/2.8 G ED, Nikkor AF-S 70-200 f/2.8G E VR II
JeffreyG "my bits and pieces are all hard" More info | Jan 07, 2012 18:30 | #2 For what? Both are good as paperweights. My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
Jan 07, 2012 18:31 | #3 I'm looking for a decent fast lens. Nikon D4S, D3, Nikkor AF-S 50 f/1.4G, Nikkor AF-S 85 f/1.8G, Nikon AF-S 24-70mm f/2.8 G ED, Nikkor AF-S 70-200 f/2.8G E VR II
xarqi Cream of the Crop 10,435 posts Likes: 2 Joined Oct 2005 Location: Aotearoa/New Zealand More info | Jan 07, 2012 18:35 | #4 Do you use your 24-70 more often around 30 or 50? Wouldn't that be your answer?
compudaze Member 121 posts Joined Nov 2011 More info | Jan 07, 2012 18:35 | #5 For indoors I would go with the 30mm. I have a 50mm on my crop body and I can't back up far enough to get anything other than half body shots of my 2 year old most of the time. Canon EOS 60D Gripped, Sigma 17-50mm f/2.8, Canon 70-200mm f/4L IS, Canon 55-250mm IS II, Canon 28mm f/1.8, Canon 85mm f/1.8, 2x Canon Speedlite 430EX II
DDL Senior Member 453 posts Likes: 25 Joined Jan 2009 Location: Alberta, Canada More info | Jan 07, 2012 18:36 | #6 alexxn wrote in post #13664825 I'm looking for a decent fast lens. Both can be bought in a fast (1.4/1.2) version - what are you going to be using the lens for? DDL
JeffreyG "my bits and pieces are all hard" More info | Jan 07, 2012 18:36 | #7 xarqi wrote in post #13664838 Do you use your 24-70 more often around 30 or 50? Wouldn't that be your answer? Or, do you get more shots at 30mm or 50mm with the 24-70 that would have been better if you had a faster aperture available than f/2.8? My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
Jan 07, 2012 18:38 | #8 DDL wrote in post #13664843 Both can be bought in a fast (1.4/1.2) version - what are you going to be using the lens for? General walkaround, indoors, outdoors, etc. need to be known before someone can suggest what would likely be right for you. It's mostly for indoor low light situations. Nikon D4S, D3, Nikkor AF-S 50 f/1.4G, Nikkor AF-S 85 f/1.8G, Nikon AF-S 24-70mm f/2.8 G ED, Nikkor AF-S 70-200 f/2.8G E VR II
DDL Senior Member 453 posts Likes: 25 Joined Jan 2009 Location: Alberta, Canada More info | A 30 to 35 mm f/1.4 would probably be your best bet if you want to shoot indoors without a flash. There are several good choices in this segment from a Canon 35mm f/1.4L, Sigma 30mm f/1.4, Canon 35mm f/2 (might be a little too slow). DDL
JuliusUpNorth Senior Member 522 posts Likes: 1 Joined Jun 2007 Location: Whitehorse, Yukon Territory, Canada More info | Jan 07, 2012 18:48 | #10 Take a look at your photos to find out what focal lengths you use most. Either way, I would prefer the 30mm for indoor use on a crop…
twoshadows Liquid Nitrogen 7,342 posts Gallery: 52 photos Best ofs: 19 Likes: 4904 Joined Jul 2007 Location: Between the palms and the pines. More info | Jan 07, 2012 19:16 | #11 DDL wrote in post #13664873 A 30 to 35 mm f/1.4 would probably be your best bet if you want to shoot indoors without a flash. There are several good choices in this segment from a Canon 35mm f/1.4L, Sigma 30mm f/1.4, Canon 35mm f/2 (might be a little too slow). As stated before 50mm is a bit too long to use indoors in house rooms if you want to get more than just head shots. However, using a flash with any of these fast lens will likely give you a better picture than just counting on low ambient light - less noise and better white balance are benefits of using the flash. Agreed. One thing I'd like to add is that the canon 28mm f/1.8 has very accurate (and quick for a wide) AF. Plus it has a small MFD. It's not f/1.4 though. xgender.net
amfoto1 Cream of the Crop 10,331 posts Likes: 146 Joined Aug 2007 Location: San Jose, California More info | Jan 07, 2012 19:30 | #12 On your crop, the 30mm (or Canon 28mm) is a "normal" lens. And, a 50mm is a short telephoto. Neither is "best", nor is either "too short" or "too long"... They serve difference purposes. You just need to decide your purpose for the lens, then base your decision on that. Alan Myers
Jan 07, 2012 21:03 | #13 Get them both and see which one you like best. Send the other one back.
| Latest registered member is MWCarlsson 1263 guests, 173 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
