Thread started 08 Jan 2012 (Sunday) 10:04
on board flash issues since i bought a 430exII
TheNewGuy01
Jan 08, 2012 10:04 |  #1
I recently purchased a 430EXII (New) for my XSi (450D) camera which I can not be happier with the results. There is no problems with this configuration. However after a month or two I found my self needing a flash and I did not have my 430II on me. I tried to use the pop up flash which used to work fine and it would not pop up. I tried to access the "Built-in flash func. setting" menu and the error I get is "This menu cannot be displayed. external flash is attached" This error is displayed when the hot shoe is empty.
I already contacted Canon tech support and they told me to "CLEAR ALL CAMERA SETTINGS" and "CLEAR ALL CUSTOM FUNCTIONS". This did not work :( . Canon requests that if this did not work to ship it back. I do not want to be without my camera or the $$ that it will cost. I am inclined to forget about it and never look back and just use my external flash but it just bugs me that this does not work.
Has anyone seen this before or as any ideas that I can try to fix this??
Bill
EOS 80D, EOS 450D/XSI, EF 50mm F1.8 STM, EF 100mm F/2.8 macro, Tamron SP 17-50MM F/2.8 XR Di II VC, EF-S 18-55mm IS, Tamron 70-300 Di VC USD, 430EXII
Ricoh KR-5 Super 52mmf2
smorter
Jan 08, 2012 10:06 |  #2
Basically under the two hotshoe elevated rails you will see these little metal railings underneath, that when a hotshoe flash is attached to it, the hotshoe will push those 2 railings underneath and keep them down. That's how the camera knows if there is something in the hotshoe or not.
It sounds like they are stuck at the moment and you might try just gently getting jiggling those metal thingys underneath the hotshoe railing, it might fix it up.
I know my description above is terrible, but if you type in the error message in google images you should get an image of what I mean
Wedding Photography Melbourneexternal link
Reviews: 85LII
smorter
Jan 08, 2012 10:07 |  #3
Here: :D
http://byrev.org …t-in-flash-doesnt-pop-up/ (external link)
Reviews: 85LII
xhack
Jan 08, 2012 13:51 |  #4
To supplement smorter's post, the micro-switch that cuts out the pop-up flash is usually on the left side of the hotshoe. In this shot, it's the grey thing under the leaf spring. It sometimes sticks and may need 'working' by manipulating the leaf spring with a toothpick.
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://i17.photobucket​.com …86/hectormac/IM​G_1518.jpg (external link)
~ Wallace
TheNewGuy01
Jan 08, 2012 16:57 |  #5
That is exactly what I was looking for. Thank you. I will try it when I get home.
TheNewGuy01
Jan 08, 2012 18:18 |  #6
That did it. Works now. Thank you again!!!!
Keyan
Joined Mar 2011
Jan 08, 2012 18:21 |  #7
This design still confuses me. Why can't the camera just do a voltage check or some other method rather than that little sticky mechanical switch to determine if something is in the shoe? I guess there are some passive accessories that have no conductive or active components but sit in the hotshoe.
Cameras: 7D2, S100
Lenses: 17-55 f/2.8 IS USM, 18-135 STM, 24-70 f/4L IS USM, 50 f/1.4 USM,70-300L IS USM
Other Stuff: 430 EX II, Luma Labs Loop 3, CamRanger
bllpt13
Jan 08, 2012 18:23 |  #8
That happened to me a week or so ago. Good thing I had read a thread just like this one a while back. Knew what the problem was immediately and fixed it right away.
Thanks POTN
1,208 views & 0 likes for this thread
Latest registered member is rob8604025
1122 guests, 149 members online
