I shoot with a 5d Mark II and use Photoshop Elements 7. It always seemed to work fine, but suddenly the program tells me that CR2.RAW is not a valid format. WTH?!?!?! Anyone else have this problem?
cameraguy1972 Member 101 posts Likes: 4 Joined Sep 2011 More info | Jan 08, 2012 16:53 | #1 I shoot with a 5d Mark II and use Photoshop Elements 7. It always seemed to work fine, but suddenly the program tells me that CR2.RAW is not a valid format. WTH?!?!?! Anyone else have this problem?
Rimmer Goldmember 1,416 posts Likes: 4 Joined Nov 2010 More info | Jan 08, 2012 17:17 | #2 Make sure you have at least ACR 5.2 installed (which apparently you did if it worked before). Here's Adobe's step-by-step procedure for troubleshooting ACR: Ace Rimmer -- "What a guy!"
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Jan 08, 2012 18:13 | #3 Do you mean, perhaps, that it always seemed to work fine with a different camera? Every model has its own version of CR2, so the converter has to date from after the release of the camera. Elie / אלי
Jan 08, 2012 19:14 | #4 For clarification, PSE 7 worked with my current 5D Mark II (the same one I am having problems with now). I will check the ACR thing.
tonylong ...winded More info | Jan 08, 2012 20:16 | #5 cameraguy1972 wrote in post #13670113 For clarification, PSE 7 worked with my current 5D Mark II (the same one I am having problems with now). I will check the ACR thing. I believe that I've seen ACR get messed up somehow and that I had to re-install it. Tony
| Latest registered member is johntmyers418 1052 guests, 146 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
