AGENT5150 Member 124 posts Joined May 2008 More info | Jan 09, 2012 03:20 | #1 Thanks for looking Canon 20D Gripped Sigma 18-50mm Sigma 70-300 Three Yongnuo YN560 Cactus V5
groovehouse Senior Member 287 posts Likes: 1 Joined Mar 2010 Location: Houston, TX More info | Jan 09, 2012 14:04 | #3 You don't have any EXIF data on your photo. Showing that info can help with feedback.
Jan 09, 2012 16:07 | #4 Canon 20d Canon 20D Gripped Sigma 18-50mm Sigma 70-300 Three Yongnuo YN560 Cactus V5
groovehouse Senior Member 287 posts Likes: 1 Joined Mar 2010 Location: Houston, TX More info | Jan 09, 2012 18:04 | #5 See what you can do to get that shutter speed up to at least 500+. You may have to up your ISO a touch or bring down your F-stop. You are at a good starting point, just start tweaking from there.
Jan 09, 2012 21:23 | #6 groovehouse wrote in post #13675942 See what you can do to get that shutter speed up to at least 500+. You may have to up your ISO a touch or bring down your F-stop. You are at a good starting point, just start tweaking from there. Thanks Canon 20D Gripped Sigma 18-50mm Sigma 70-300 Three Yongnuo YN560 Cactus V5
cronu Member 237 posts Joined Nov 2006 Location: Austin, TX More info | Jan 09, 2012 22:10 | #7 The barrier is a little blown out and as mentioned above there is some motion blur. Unless you have speedlites or strobes to use highspeed sync, you will be stuck with shooting at 1/250. So you can power them flashes up more and shoot with a smaller apture. This will stop the motion a little more and allow you to get way with using flashes in that bright of ambient light. 60D
groovehouse Senior Member 287 posts Likes: 1 Joined Mar 2010 Location: Houston, TX More info | Jan 10, 2012 09:41 | #8 cronu wrote in post #13677407 The barrier is a little blown out and as mentioned above there is some motion blur. Unless you have speedlites or strobes to use highspeed sync, you will be stuck with shooting at 1/250. So you can power them flashes up more and shoot with a smaller apture. This will stop the motion a little more and allow you to get way with using flashes in that bright of ambient light. Cronu is totally correct. I forgot about the highspeed sync and 1/250 limitation.
LightSniper Member 42 posts Joined Dec 2011 More info | Jan 11, 2012 10:31 | #9 yo 5150- 7D gripped/70-200 2.8 IS USM II/50 1.4/10-20 4
cronu Member 237 posts Joined Nov 2006 Location: Austin, TX More info | Jan 11, 2012 16:21 | #10 I wouldn't worry too much about the flash messing a skater up, especially during the day. Using a fast shutter speed without a flash will stop the action just as a multiple flashes powered high will, but the skater will not stand out much. I think you were on the right path, just a little more flash power and higher f-stops. Back Smith Then here is a natural light shot that I wish I would have used some flashes to really help him pop out. This shot is kind of a boring shot, but could have been better with flashes IMO.(and maybe tighter composition too) IMAGE LINK: http://www.flickr.com …s/cronuflicks/6303741924/ Front Rock 60D
| Latest registered member is josetide 1050 guests, 167 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
