Thread started 09 Jan 2012 (Monday) 23:02
Reikan FoCal M/A software test on 7D
Buylongterm
Jan 09, 2012 23:02 |  #1
So here are some of my results with my 7D and my 70-200mm 2.8 IS II. I apologize in advance. The tests are inconsistent. I should of tested both focal ranges for each test. didn't realize this till the end and by then I was freezing my ass off. :)
All tests and pics were done at 50x max focal length (just used a electric box on the side of the house which had #'s on it)
Shots:
MA=0 @ 70mm
MA=0 @70mm (cropped)
MA @ 0
200mm
MA @ 0 (cropped)
Test 1.
MA=0
results:MA +10
IMAGE: http://farm8.staticflickr.com/7011/6670908531_403593513f_b.jpg
200mm
200mm (cropped)
Christian
@WerthLiving (Follow me on Instagram)
Canon EOS 5D MK III Gripped | 35mm f/1.4L | 70-200mm f/2.8L IS MK II |100mm f/2.8L Macro | 24mm-105mm f/4.0L |
Buylongterm
Jan 09, 2012 23:03 |  #2
Test 2.
Left MA @ +10
error message:
Click yes
results:
+11
Results: +11
@200mm
@200mm (cropped)
Christian
Buylongterm
Jan 09, 2012 23:07 |  #3
Test 3.
MA= +11
results:
MA +11 (no change)
Test 4.
MA=0
Error message:
Clicked yes
Results:
MA= +9
(no screenshots)
Test 5
MA=0
Results
MA=+8
@200mm
@200mm (cropped)
@70mm
IMAGE: http://farm8.staticflickr.com/7012/6671150503_f6b8d28b99_b.jpg
@70mm (cropped)
IMAGE: http://farm8.staticflickr.com/7154/6671150743_6157d65669_b.jpg
test 6 & 7
MA=+8
results: No change.
Last test, just moved the tripod from around 10.2m to 9.4
results: +4
So, what did I learn? this is very time consuming. I have a ton of respect for everyone who does any sort of testing for the board. However next time, I need to be more consistent. Wearing a warmer jacket would of helped. :-) I haven't even compared pics that much, but a quick glance says MA+11 looks really good compared to leaving it at 0 and +8 isn't to bad either. But I gotta look more closely at the 70 range. Perhaps I'll find a range somewhere in the middle
Christian
StructuredAmazing
Jan 09, 2012 23:25 |  #4
Buylongterm wrote in post #13677638 (external link)
Shots:
MA @ 0
200mm
HTTP response: NOT FOUND | MIME changed to 'text/html' | Content warning: script
MA @ 0 (cropped)
Test 1.
MA=0
results:MA +10
200mm
200mm (cropped)
Is this micro adjust software available for the Canon 17-55mm lens? Is it recommended to use this software for your lens?
"Yea, though I walk through the valley of the shadow of death, I will fear no evil"
StructuredAmazing forever.
My website: Pending...
MATT0404
Jan 09, 2012 23:46 |  #5
Out of curiosity, why didn't you use the focus test charts that are included with the software?
500px (external link)
Buylongterm
Jan 09, 2012 23:47 |  #6
StructuredAmazing wrote in post #13677741 (external link)
From everything I've read, people are getting fantastic results. The software is only compatible with the 5D and 7D at the moment. Being fairly new to all this, the software is extremely user friendly. It works with all lenses on either camera.
Christian
Buylongterm
Jan 09, 2012 23:50 |  #7
MATT0404 wrote in post #13677837 (external link)
I did. The pics above are just shots after doing the tests using the chart that comes with the software. If you look at my pics with the software, the rings are from the printout.
Christian
MATT0404
Jan 10, 2012 00:05 |  #8
Buylongterm wrote in post #13677851 (external link)
Ahhh, ok. I'm using the software, too, and can't say that I've had consistent results.
On my 100-400L it recommended a setting of +5 at 400mm and -11 at 100mm. Confused, I tried the test again during the day in much better lighting. This seemed to help, as it recommended -2 for both 100 and 400mm.
Buylongterm
Jan 10, 2012 00:17 |  #9
MATT0404 wrote in post #13677913 (external link)
My tests pretty much showed the same thing. Nothing to consistent. But it definitely helped me realize that my lens definitely needs to be MA. Deciding what setting I'm going to use will be the hard part. Going to run more tests before the temp drops back into the low 20's
However my real question is if my lens needs that big of an adjustment, shouldn't it go back to canon for calibration???
Christian
John_T
Gallery: 127 photos
Joined Jun 2003
Jan 10, 2012 01:41 |  #10
I did my first runs a week ago using the default settings, being reasonably careful with the whole setup and got good and consistent results.
Yesterday I started through all my lenses and bodies again using the strictest settings, which required better lighting, perfect target alignment, rock-solid tripod/head stability. Basically I set everything up like a transit on a construction site. Stretched a string perpendicular to the target 15 meters long to keep the tripod aligned at each distance. This all tightened the results, some staying the same, some deciding a point or two better than the first run.
The results reflect what you put into it and once you've gotten it down, I think you will get very precise and consistent results, or get shown that you gear is not as precise and consistent as you thought it was.
I found that Poor AF Performance warning to be primarily due to imperfect target alignment, meaning you get the green check in the Fit view, but a red X in the Zoom view. I found this to be particularly touchy with the 85L because of the ultra thin DOF. Conversely the 50 f/1.4 was touchy as hell cause its AF mechanics are erratic as hell.
If you get the Poor AF Performance warning you can try to refine alignment or stabilize your platform, but you can also click Yes to continue and you may still get a good result.
Doing this outdoors, if you've got some wind, may not be a good idea.
Canon : EOS R : 5DIV : 5DS R : 5DIII : 7DII : 40 2.8 : 50 1.4 : 35L : 85L : 100L IS Macro : 135L : 16-35L II : RF-24-105L IS : 70-200L II : 100-400L IS II : 1.4x & 2x TC III : 600EX-RT : 580EX : 430EX : G1XII : Markins Q10 & Q3T : Jobu Gimbal : Manfrotto Underware : etc...
Buylongterm
Jan 10, 2012 09:49 |  #11
Great points and great advise! Im going to try the tests again. Problem is I'll have to wait for the weekend and by then it will be cold and windy.
Christian
John_T
Gallery: 127 photos
Joined Jun 2003
Jan 10, 2012 11:28 |  #12
If you've got 10 meters and good lights inside, why not do it inside?
Buylongterm
Jan 10, 2012 14:00 |  #13
John_T wrote in post #13679993 (external link)
Because I don't have 10meters and I don't have good light inside. :)
Christian
Buylongterm
Jan 10, 2012 14:41 |  #14
So, I did some comparing, and from my initial tests, MA +8 looks much better than than leaving it at MA 0 (see images)
200mm cropped (no Micro Adjustment)
200mm cropped (+8 Micro Adjustment)
70mm cropped (no Micro Adjustment)
70mm cropped (+8 Micro Adjustment)
Christian
John_T
Gallery: 127 photos
Joined Jun 2003
Jan 10, 2012 15:03 |  #15
...eeeYup.
6,544 views & 0 likes for this thread, 5 members have posted to it.
1468 guests, 130 members online
