Thread started 10 Jan 2012 (Tuesday) 03:10
A Few More Stage Shots From The GNCWF
Abbo
Jan 10, 2012 03:10 |  #1
A few more from the GNCWF festival pics.
IMAGE: http://i37.tinypic.com/4gpu9l.jpg
IMAGE: http://i35.tinypic.com/jh3h8p.jpg
IMAGE: http://i33.tinypic.com/znat7p.jpg
IMAGE: http://i35.tinypic.com/afj574.jpg
Thanks for looking
John.
rick_reno
Jan 10, 2012 22:21 |  #2
nice set, looks like low light
WSFD44
Jan 11, 2012 21:18 |  #3
I like #2 the best..... Does look like real low light..... If you don't have f2.8 glass, shoot RAW with a higher ISO and clean up the noise in processing..... What body are you using?
5D MkIv, 1D MkII, 1D MkIII, 40D and a bunch of stuff.
Abbo
Jan 12, 2012 01:26 |  #4
I was using my Canon EOS 400 D with the Tamron 18-270mm 1:35-6.3 IS luns the biggest ISO i can get is 1600 so will try again with that nixt time and see how things go.
Thanks John
WSFD44
Jan 14, 2012 19:12 |  #5
Someone may have mentioned it in your other set.... Try setting the center AF point. Looks like the AF grabbed the pesty pole in the last shot....
René ­ Damkot
Jan 19, 2012 13:06 |  #6
Yeah, a higher ISO goes a long way. As does shutting off the flash.
Also: Get the subject out of the center. Focus-recompose if that's the only way to do it, or frame a bit loose and crop.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
1,558 views & 0 likes for this thread, 4 members have posted to it.
1865 guests, 101 members online
